Thread: 97 GTP engine codes
Results 1 to 6 of 6
  1. #1 97 GTP engine codes
    Apr 2009
    winnipeg
    hi i have a 97 GTP with k&n air filter, lowered, 3" dual exhaust,freshly rebuilt stage 2 transmission.the car runs great but from an idle in park there is a slight lag when you firt rev the motor,,, as in rpm tends to drop a little then picks right up.everything look conected and in the right place.
    i am getting 2 codes,the first is p0102 mass air flow sensor, i did change this map sensor after installing a new k&N filter so it was dry and not to contaminate the sensor, the second code was p1655 evap emissions purge control solenoid which i replaced also but tend to get this code once in awhile, the car has new iridium plugs in it also, another thing i notices is i only get half boost on the gauge even at full throttle,also there is less boost the faster you are going example only get 1 or 2 bars boost when at 120 klm and you giver.any idea on this will be greatly appreciated.....
  2. #2 Re: 97 GTP engine codes
    Plug Wires, Coil Packs, ICM...or Vacuum Leak.
  3. #3 Re: 97 GTP engine codes
    Feb 2008
    I'm going to say a vac leak. Most likely at one of the boost bypass solenoid lines and possibly at the purge solenoid line.
  4. #4 Re: 97 GTP engine codes
    HVAC...
  5. #5 Re: 97 GTP engine codes
    Apr 2009
    winnipeg
    i noticed that the vacuum line that goes to the evap canister. it dosent go to the canister because there seems to be no canister lol, the vacuum line goes under master cylinder and plugs into one of the metal lines running alone side the metal fuel lines runing to the fuel tank.does anyone know were the evap canister it to be located?also were is the best place to find a canister? also looking for a complete vacuum diagram for 97 gtp.. thanks for the help so far ....greatly appreciated
  6. #6 Re: 97 GTP engine codes
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    Here is a diagram for you
  1. how to get codes
    By bowtechguy in forum General Tech Discussion
    Last Post: 04-16-2009, 05:19 PM
  2. Have some codes need help
    By pDuB257 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-26-2009, 03:25 PM
  3. Check Engine Light on - Codes included
    By jcapone in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-06-2009, 02:04 AM
  4. engine light/trouble codes
    By Jakegday in forum General Tech Discussion
    Last Post: 01-02-2009, 08:03 PM
  5. 3 codes, what could it be?
    By spidamanSS in forum General Tech Discussion
    Last Post: 08-19-2008, 02:24 AM
