Thread: car wont start
Results 1 to 14 of 14
  1. #1 car wont start
    GXP Level Member ryangtp89's Avatar
    Maine
    Car wont start after the 1.9 rocker install, the starter works but idk whats up with it. The only thing i can think of that might be messed up is the wires i had to solder together. Its the wire that goes to the coil its purple and its connected to another peice that wraps around the whole car, soo idk what to do. I put in my stock pcm just to see if it will start. I'm just not getting any spark. I have all of the wires hooked up and i have all the plug wires in the right spot.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: car wont start
    Why did you cut the wire to begin with?
    Also if you get that figured out what did you torque the rockers too...if you tq'ed them too much it won't start either.
  3. #3 Re: car wont start
    Maine
    The wire broke soo i had to solder it back. I trq the rockers to 11ft pounds plus 90 degrees maybe ia few degrees more.
  4. #4 Re: car wont start
    What happened to 25ft. lbs?!?!
  5. #5 Re: car wont start
    Barksdale AFB, LA
    For rockers? Hell no. The stock OEM bolts are 11ft-lbs + 90* according to the GM SI.
    For the reusable bolts, it's 23ft-lbs.
    2009 Subaru Impreza WRX STI
  6. #6 Re: car wont start
    Maine
    I got instructions from both zzp and intense racing and they said 11ft lbs plus 90 degrees
    I'm more concerned with the wires i soldered. The wire that broke off is a purple wire that connects to the coil pack plug in, and that wire was connected to another wire that wraped all around the firewall, i wish i had some pics to make it easyer to explain.
  7. #7 Re: car wont start
    Maine
    ttt
  8. #8 Re: car wont start
    Barksdale AFB, LA
    Did you put the ICM ground back on? The little wire with a ring terminal that goes on a bolt by the SC belt tensioner?
  9. #9 Re: car wont start
    Maine
    yep i made sure that ground went against the block or head.
  10. #10 Re: car wont start
    SE Level Member comongoose's Avatar
    Jan 2009
    Gainesville, Fl
    I am having the same problem. But I do not see a ground wire from my icm. does any one have a picture? I though the thing underneath it grounds it.
    -1999 GTP...Work in Progress! L26 bottom end, K&N HAI, ZZP MPS 3.5" pulley, headers, custom intake, 180 therm., 1.9 rockers
    -1996 Acura TL
    -1995 Trans Am...SOM beast...RIP.
  11. #11 Re: car wont start
    Barksdale AFB, LA
    Quote Originally Posted by comongoose View Post
    There's a single wire that comes off the harness somewhere and goes to a ring terminal on one of the bolts that holds the coil pack bracket to the head. It's all under the coil packs and ICM and down by the SC belt tensioner and the idlers.
    You can see it in this pic. It's coming off a harness in the left side of the image. Look over by the crank pulley. Just chilling in open air (since my motor was torn down). At least lets you know what it looks like...
    http://img.photobucket.com/albums/v3...p/DSC02752.jpg
  12. #12 Re: car wont start
    Jan 2009
    Gainesville, Fl
    o ok thanks....I think i have that grounded to my ac compressor...lol. Is the tach suppose to go up and down while cranking, because mine just sits at 0 rpm.
    -1996 Acura TL
  13. #13 Re: car wont start
    Barksdale AFB, LA
    On every car I've been in the gauges stay dead while cranking to leave more power for the starter.
  14. #14 Re: car wont start
    Jan 2009
    Gainesville, Fl
    same here, but i think some one in a previous thread said something about it...I've tried almost everything except the CPS, but i find it hard to be broken after only 26k miles.
    -1996 Acura TL
  1. car wont start right away .
    By NEONNIGHT34609 in forum General Tech Discussion
    Last Post: 02-15-2009, 01:40 PM
  2. car wont start
    By 98gpgtp in forum General Tech Discussion
    Last Post: 10-22-2008, 05:26 PM
  3. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  4. Car wont start need help!!!!
    By drums4life0922 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 09:34 AM
  5. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
