Thread: mod suggestion while motor is out.....
Results 1 to 17 of 17
  1. #1 Re: mod suggestion while motor is out.....
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by TDCRacing View Post
    What cam were you running.
    Gooch = Corey
    Quote Originally Posted by FoSHO99 View Post
    LS6 springs, S1X and new stock timing chain... the corey combo.
    The xp cam has a bit more noticable lope at idle too.
    Screw em both and get the NIC cam... LOL
  2. #2 Re: mod suggestion while motor is out.....
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    send me the $1000 and i'll send u the ultimate sticker kit, best bang for the buck!lol
  3. #3 Re: mod suggestion while motor is out.....
    SE Level Member Sinister Drag Designs's Avatar
    s1x cam
    105 springs
    cc retainers
    stock chain and damp
    viton valve seals
    gaskets for swap
    pacesetter headers/reworked ebay knockoffs
    HAI
    MPS with 3.2
    smaller belt
    NGK tr6 plugs
    180 t-stat
    TUNE
    Great street manners, should still be able to use stock injectors.
    That should blow about the whole budget if you can get some stuff used.
    Or ditch the cam and 105 springs, get used 1.9 modified rockers, a used nitrous kit, and run a 3.4 pulley. This might be a little easier on the trans if you are only using the nitrous kit at the track and not spraying through the shifts.
    Both setups have been proven power makers for years. Whats your goal for the car powerwise?
  1. Suggestion
    By Dohner in forum Forum Bugs/Suggestions
    Last Post: 02-08-2009, 04:19 PM
  2. Randomness .... Suggestion
    By Billyboi6 in forum Off Topic Discussion
    Last Post: 11-24-2008, 05:48 PM
  3. Muffler suggestion/ experience
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-15-2008, 05:02 PM
  4. Transmission Area Suggestion
    By 19SE92 in forum Forum Bugs/Suggestions
    Last Post: 02-12-2008, 09:41 PM
  5. Another Forum Suggestion
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 12-29-2007, 03:00 PM
