Thread: water pump
Results 1 to 4 of 4
  1. #1 water pump
    SE Level Member Ramondo411's Avatar
    Apr 2009
    Rotterdam,New York
    i had just put in a new water pump an flushed my radiator...an assumin i still have air in my lines, cause shes runnin really hot! im new to this stuff so any kinda help would be appreciated.
    to release the air out would there be a screw lookin thing comin out of the top of my engine its right after the main hose that goes from my radiator to my engine? im not quite sure if that would be it
  2. #2 Re: water pump
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Yes, the bleeder screw is the one on top of the thermostat housing. Open it slowly, and keep bleeding it and adding more to the radiator (not just the overflow tank), until you get coolant coming out with no air.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: water pump
    Apr 2009
    Rotterdam,New York
    thanks scimmia everything worked out for me. i figured that was it, but thank you she seems to be runnin at normal temps
  4. #4 Re: water pump
    It'll run hotter with a stock thermostat
  1. Water pump problems?
    By gtbe4 in forum General Tech Discussion
    Last Post: 04-21-2009, 09:07 AM
  2. 3.1 water pump housing?
    By bfx racing in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-20-2009, 10:48 PM
  3. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
  4. Quick question (water pump)
    By cgator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-02-2008, 08:03 AM
  5. Quick question (water pump)
    By cgator in forum General Tech Discussion
    Last Post: 09-21-2008, 10:13 PM
