Thread: Rockers break in
Results 1 to 20 of 29
  1. #1 Rockers break in
    Barksdale AFB, LA
    I changed my oil for the first time since the swap. I had been running dino oil for the first 500 miles and wanted to get back to Royal Purple. Anyway, on my magnetic drain plug there was a little material.
    I would think some material is expected as the pushrods break in their new seats on the rockers. Just want to make sure this is normal and not something I should worry about. Thanks!
    2009 Subaru Impreza WRX STI
  2. #2 Re: Rockers break in
  3. #3 Re: Rockers break in
    Barksdale AFB, LA
    there is no break in period for rockers..
    According to the instructions that came with the rockers there is. 250-500 miles.
  4. #4 Re: Rockers break in
    Jersey
    you also basically have a whole new top to your motor, it's probably normal.
    16' wrx sti- stock
  5. #5 Re: Rockers break in
    as soon as you start the motor they are pretty much worn in. there is nothing in this motor that you cant just beat on it pretty much right when you get done with putting it together.
    besides, if you want the motor to run hard you have to break it in hard.
  6. #6 Re: Rockers break in
    Barksdale AFB, LA
    It's plenty broke in by now. I've made sure of that.
  7. #7 Re: Rockers break in
    Figure everything needs to be broken in...that is why I took it WAY easy the first 1,000 miles or so...
  8. #8 Re: Rockers break in
    Jersey
    Ill probably shatter my tranny the first day i get mine tuned
    16' wrx sti- stock
  9. #9 Re: Rockers break in
    Barksdale AFB, LA
    With my shift kit my tranny is doing great. WOT shifts are only 150-175ms.
  10. #10 Re: Rockers break in
    Jersey
    Quote Originally Posted by Sabrewings View Post
    Intense shift kit ftw. So tell me...can you spin going into 2nd?
    16' wrx sti- stock
  11. #11 Re: Rockers break in
    Quote Originally Posted by 99prixgt View Post
    thats easy with the m90.
  12. #12 Re: Rockers break in
    Banned - Busted For Scamming
    Feb 2009
    i must have horrible kr then... .cause i cant.
  13. #13 Re: Rockers break in
    mine will go straight through first gear, spin into second, and then grip. i dont really ever do it because i like my transmission the way it is..not broke.
  14. #14 Re: Rockers break in
    Barksdale AFB, LA
    With full timing I get a hell of a chirp for about a second. I don't know if that disqualifies it from being a chirp or not.
    Earlier today I hit a slight bump at about 40MPH in a WOT run and got the wheels spinning until it upshifted. That was pretty cool.
  15. #15 Re: Rockers break in
    3.29's own the tires...I spin though 1st and 2nd and grab 3rd LOL
  16. #16 Re: Rockers break in
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    I have personally never heard on breaking in rockers, but if the manufacture says that there is a break in period, then I guess there is.
    If you feel that the metal shavings were in excess, then go ahead and throw in some more oil and a filter and run it for another 500 miles, and change the oil again.
    if its clear, then go ahead and run the synthetic or royal and go on with life. if there is still some damage, it may be time to see if there isn't something more serious going on.
    Engineering the impossible.
  17. #17 Re: Rockers break in
    Barksdale AFB, LA
    Lol, changing the oil in another 500 miles can get expensive. I just switched back to Royal Purple and that stuff gets more expensive every time I buy it. $8.57 a quart now. Another oil change is just too much.
    I think it's fine. Most of that probably came from the minor imperfections in the newly machined seats on the rockers. The pushrods are a harder metal and they'll wear the seats to their shape.
  18. #18 Re: Rockers break in
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Im changing my oil tommorrow after 500 miles of running the new rockers. I will see how much material is on my magnet and report back.
  19. #19 Re: Rockers break in
    Jersey
    lol thats what I want
    16' wrx sti- stock
  20. #20 Re: Rockers break in
    Damn...move to Missouri...that stuff is only $6.99 a quart here
  1. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  2. Break in oil
    By Stu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:22 PM
  3. ABS Break Control Modular
    By Jackie in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 12:33 PM
  4. GXP break upgrade
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2009, 08:39 PM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
