Thread: Working on my 1.9 rockers
Results 1 to 6 of 6
  1. #1 Working on my 1.9 rockers
    GXP Level Member ryangtp89's Avatar
    Maine
    I'm working on my backside now and i can't seem to get the lockers off, well i got one off but everytime i compress the spring down the valve goes down with it. I'm pretty sure i got enough air going through my compression gauge to the head. So idk what to do.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  2. #2 Re: Working on my 1.9 rockers
    Jul 2008
    Poteau Oklahoma
    use compressed air, use an adpter that you put in the spark plug location and hook up an air hose to it. that should solve the problem of the valve falling, and to get the locks off when the spring is compressed tap the top of the valve with a hammer.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: Working on my 1.9 rockers
    Moore, Oklahoma
    Quote Originally Posted by justwhisen View Post
    Yep, this is exactly what I did for mine. I used a good rubber mallet to "loosen" the locks before removing. They would do the same thing yours is doing. Took probably 3 or 4 taps a valve to free em up enough to use my compressor tool. My springs had 150,000 miles on them when I replaced them, so they were "locked in" good!
    Shawn W. Larsen
  4. #4 Re: Working on my 1.9 rockers
    Jul 2008
    Germantown, Maryland
    good post
  5. #5 Re: Working on my 1.9 rockers
    St. Louis Mo.
    Moved to its correct section.
    James Shafer
    St. Louis MO
  6. #6 Re: Working on my 1.9 rockers
    Maine
    I'm all set, I grabbed the wrong hose than i used the day before, the hose that wasnt working right had a shrader valve in it. Thanks for the help.
  1. Help!!! Gas Gas gauge not working
    By PontiacGTPSE in forum General Tech Discussion
    Last Post: 07-09-2009, 12:30 PM
  2. coolant fan not working
    By jpopdallas in forum Introductions/Noob Questions
    Last Post: 04-17-2009, 08:41 PM
  3. DIC working?
    By Seagya in forum General Tech Discussion
    Last Post: 05-13-2008, 07:20 AM
  4. DIC not working
    By sausmonkey in forum General Tech Discussion
    Last Post: 04-25-2008, 11:21 AM
  5. gauges not working?
    By s1795so2 in forum General Tech Discussion
    Last Post: 01-13-2008, 12:11 AM
