Thread: Gen V Swap, Slow Blower Boost
Results 1 to 7 of 7
  1. #1 Gen V Swap, Slow Blower Boost
    SE Level Member scottmmckinney's Avatar
    Apr 2009
    Chesterton, IN
    Hi Guys. I just recently completed my Gen V blower swap but have a few questions for any experienced swapping experts.
    First of all, it seems that the boost and power are not as quick as my Gen III at lower rpms. Once the engine rpm shoots up, the blower is more powerful yes. Is this normal?
    Next, I noticed the BBV mounting bracket is slotted to mount it higher or lower. Does it matter how it is mounted? What is the difference?
    And, is a new tune recommended or beneficial for this swap?
    I appreciate your help! Please advise.
  2. #2 Re: Gen V Swap, Slow Blower Boost
    First question is what are all of your mods? If you are running the same size pulley as the GenIII then there is the first issue...you've got to compensate for the more efficient supercharger that you've got...
  3. #3 Re: Gen V Swap, Slow Blower Boost
    Apr 2009
    Chesterton, IN
    These are my mods:
    3.3" Modular Pulley System, Black Aluminum
    Gen V Ported Blower Assembly
    Ported L67 Throttle Body w/Billet Adapter
    1.9 High Ratio Rocker Rocker Arms
    Full Length Stainless Steel Headers
    3" Catless Stainless DownPipe
    Custom Fenderwell Air Intake System
    Ported & Machined Lower Intake Manifold
    Mezeire Electric High Flow WaterPump
    Custom Throttle Body Heat Shield
    MSD Coil Packs & Ignition Wires
    Custom 160 Degree Drilled Thermostat
    Autolite 104 Colder Heat Range Spark Plugs
    Cometic High Compression Head Gaskets & ARP Studs
    Gatorback Supercharger & Accessory Drive Belts
    Custom Built Shift Kit & Accumulator Modification
  4. #4 Re: Gen V Swap, Slow Blower Boost
    Jersey
    Quote Originally Posted by scottmmckinney View Post
    The way i mounted my bbv, is i put the screws in almost snug, so the bracket still slides, then i opened the valve manually while completely opened, i then tightened the bolts snug, so the valve can open and close without getting binned up. Hope this helps.
    16' wrx sti- stock
  5. #5 Re: Gen V Swap, Slow Blower Boost
    Nice list...
    Do you not have a tune?! That might be the issue right there
  6. #6 Re: Gen V Swap, Slow Blower Boost
    Apr 2009
    Chesterton, IN
    Nice list...
    I currently have a junky ZZP 1.0 PCM, but have an appointment with PRJ for later this month...
  7. #7 Re: Gen V Swap, Slow Blower Boost
    Yup...I'd be willing to bet that is the issue RIGHT there...
    and by RIGHT I mean ZZP's POS PCM
  1. Gen V Swap, Noisey Blower Now
    By scottmmckinney in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-11-2009, 12:21 PM
  2. General Gen. V blower swap questions
    By GTPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2009, 06:38 PM
  3. what is required for a gen 5 blower swap?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:55 PM
  4. slow
    By Toasty in forum Off Topic Discussion
    Last Post: 02-12-2008, 07:03 PM
