First question is what are all of your mods? If you are running the same size pulley as the GenIII then there is the first issue...you've got to compensate for the more efficient supercharger that you've got...
These are my mods:
3.3" Modular Pulley System, Black Aluminum
Gen V Ported Blower Assembly
Ported L67 Throttle Body w/Billet Adapter
1.9 High Ratio Rocker Rocker Arms
Full Length Stainless Steel Headers
3" Catless Stainless DownPipe
Custom Fenderwell Air Intake System
Ported & Machined Lower Intake Manifold
Mezeire Electric High Flow WaterPump
Custom Throttle Body Heat Shield
MSD Coil Packs & Ignition Wires
Custom 160 Degree Drilled Thermostat
Autolite 104 Colder Heat Range Spark Plugs
Cometic High Compression Head Gaskets & ARP Studs
Gatorback Supercharger & Accessory Drive Belts
Custom Built Shift Kit & Accumulator Modification
