Thread: problems with car running
Results 1 to 5 of 5
  1. #1 Re: problems with car running
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    I dont think the two are related, (the trac light and the car dying). Are there any other symptoms like your tach bouncing? Your cam position sensor may be bad. First, check all of your grounding points to make sure they are good. One is on the tranny and the other is on the coil pack nut.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: problems with car running
    Jan 2009
    hammond, IN
    Quote Originally Posted by t24moore View Post
    my rpms will bounce sometimes but not all the time, could that be my problem?
  1. running hot ??
    By rickchall69 in forum 3.1L V6 (LHO/LG8)
    Last Post: 11-05-2009, 02:55 PM
  2. who is running E85?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2009, 06:25 PM
  3. Won't start after running out of gas
    By DesQ27 in forum General Tech Discussion
    Last Post: 02-13-2009, 07:59 PM
  4. Running Hot
    By 1998xGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2008, 10:41 AM
  5. Starting/running problems
    By 04gpgt2 in forum General Tech Discussion
    Last Post: 10-21-2008, 09:29 PM
