Thread: car only shifts when it wants to??
Results 1 to 14 of 14
  1. #1 car only shifts when it wants to??
    calgary A.B
    Ok, here is my problem... I have a 97 GT with topswap done.. When I get in the car it will shift just fine....until i turn it off, Then 9times out of ten after i restart it, it wont shift from 2nd to 3rd at all. If i turn the car off again and start it after a while it will shift fine again until yes.. i turn it off. I got it scanned and the only code that came up was P0717 input shaft speed sensor no signal? is there a problem with the tranny or my pcm not reading my tranny, Im really stuck here, any help would be great. Thanks
  2. #2 Re: car only shifts when it wants to??
    oh god, a top swapped 97. you just opened a whole new can of worms with that. you should have saved yourself a ton of hassle and just done a motor and transmission swap. that vacuum controlled tranny you got right now will never work well with the blower setup without a retarded amount of stupid work. i would kill myself if i would be in your situation.
    all i have to say is good ****ing luck.
  3. #3 Re: car only shifts when it wants to??
    calgary A.B
    wow,really that bad. i thought it might be the pcm tune,i was going to get it fixed?? aside from the changing it there is nothing i can do?? Is the tranny a b@$$#ch to get out..
  4. #4 Re: car only shifts when it wants to??
    Ummm is that a serious question?
    You either gotta pull the motor or drop out the entire subframe and pull it from the bottom.
  5. #5 Re: car only shifts when it wants to??
    if you would have asked the question 'should i top swap my 97 GT?' i would have said 'hell no. get a transmission and motor combo and drop it in.'
    seriously, it just does not work well at all.
  6. #6 Re: car only shifts when it wants to??
    You should sell it...get a GTP...it is A LOT easier that way IMO
  7. #7 Re: car only shifts when it wants to??
    calgary A.B
    Ok, i went and got my pcm tuned from a gm specialist, and wow it shifts just like new now. dont know what he did but problems are all gone.
  8. #8 Re: car only shifts when it wants to??
  9. #9 Re: car only shifts when it wants to??
    Have fun, good luck. Might have been in limp mode...
  10. #10 Re: car only shifts when it wants to??
    calgary A.B
    what do you mean "limp mode"
  11. #11 Re: car only shifts when it wants to??
    Quote Originally Posted by orange97gtp View Post
    The transmission will shift really harshly and only go into 2nd gear.
  12. #12 Re: car only shifts when it wants to??
    calgary A.B
    now thats its fixed do you think it will happen again??
  13. #13 Re: car only shifts when it wants to??
    It might...like Bio said. the '97's had a vacuum powered transmission and they were prone to having mucho problems...
    I'd save up your money and get a a race tranny built for it but Dave from Triple Edge Performance. Then you'll NEVER have any issues again
  14. #14 Re: car only shifts when it wants to??
    calgary A.B
    ok thanks guys,i will look into it.
  1. Hard Shifts.
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2009, 09:18 PM
  2. 2000 se Shifts weird
    By dozerzuki in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-14-2008, 02:29 AM
  3. my car shifts very hard when i put it in reverse
    By volsgirl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-10-2008, 04:02 PM
  4. Hesitating shifts
    By Andrew_99GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 01:03 PM
  5. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
