Thread: Break in oil
Results 1 to 7 of 7
  1. #1 Re: Break in oil
    SE Level Member Stu's Avatar
    Apr 2009
    Calgary, Alberta
    Thank you, but are there not other areas in an engine that could benefit from the ZDDP? (Provided you believe in its ability to act as a protectant)
    I have read a study that was put out by Shell regarding their Rotella with ZDDP (it seems that some hobbyists run the Rotella diesel oil in their cars for improved performance) which showed an 0.7 to 1.6 % improvement in fuel economy. That seems insignificant, but what I gather is that an improved fuel economy means less friction which in turn means less heat. Also less soot in the oil prevents the oil from thickening prematurely thus extending the usable life of the oil in the engine. It is also better for cold weather performance and here in Calgary it is not uncommon to have spells of -20 to -30 throughout the winter months.
    Please correct me if I am incorrect, because like I said, I am a noob to all of this.
    EDIT** Thanks UR LOSN. I understand that break in oil is for new engines. I was only curious because of its ZDDP properties possibly helping prolong the life of the engine.
    1997 Grand Prix GTP
    3.8 Supercharged - Stock
  1. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  2. ABS Break Control Modular
    By Jackie in forum Brakes/Suspension/Chassis
    Last Post: 03-11-2009, 12:33 PM
  3. GXP break upgrade
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2009, 08:39 PM
  4. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
  5. ABS and TCS lights are on. Break problems. Plz Help
    By Freebeer187 in forum General Tech Discussion
    Last Post: 06-22-2008, 11:58 PM
