Thread: 1.9 rocker questions
Results 1 to 20 of 21
  1. #1 1.9 rocker questions
    Donating Users ROTTMAN's Avatar
    Feb 2009
    canada
    Installed the 1.9's on Saturday. Over the last few days my car seems to be pulling harder especially between 4500-6000 rpm. Why would performance improve over 3 days of driving? Does the pcm adjust itself to this mod? I have an overkill pcm and Will said I would not have to send it back after I did the rockers. Also, would the exhaust change after this because it seems alot deeper now...
  2. #2 Re: 1.9 rocker questions
    Well the PCM has to adjust still for the difference in air movement...so it might have been learning...don't know what else it could be...maybe it will just keep getting faster and faster and FASTER LOL
  3. #3 Re: 1.9 rocker questions
    Jan 1970
    Maquoketa, Iowa
    pcm adjusts, relearn fuel trims and what did you have to eat the last few days? Maybe your butt dyno is off! lol jk
  4. #4 Re: 1.9 rocker questions
    Feb 2009
    canada
    lol thanks...maybe its my wishful thinking
  5. #5 Re: 1.9 rocker questions
    GT Level Member 04CompG's Avatar
    Feb 2008
    South Bend, IN
    i've heard but never verified that our pcm's have Adaptive Learning. Give it a week or so to determine your driving style and adjust for it.
    2004 GTP CompG. SPO Package.
    3.6MPS, 3" DP, Powerlog, 180Tstat, Wizair, Autolite 104's, 20* timing, PRJ Wires. PRJ Tune.
  6. #6 Re: 1.9 rocker questions
    Donating Users blowfishRus6's Avatar
    g.a.
    if the pcm was reset due to battery being unpluged, then yea there will be an adjustment period. 3 days is pretty good tho, after 3 days mine is getting back to normal. after a week its faster then what i started with.
    my exhuast also sounds a little throater at wot after rockers.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  7. #7 Re: 1.9 rocker questions
    any valve train mods will make the car faster regardless of the tune.
  8. #8 Re: 1.9 rocker questions
    g.a.
    it made my car faster. only thing was my pcm was reset so it took awhile for it to get things straight again.
    its slow.
  9. #9 Re: 1.9 rocker questions
    I live here. UR LOSN's Avatar
    Rockford, IL
    I believe it adjusts itself up to 5% of where the Air/fuel mixture should be.....
    so in essence....it learns!
  10. #10 Re: 1.9 rocker questions
    GTP A.I.
  11. #11 Re: 1.9 rocker questions
    Aug 2008
    Long Island, New York
    i want some rockers.
  12. #12 Re: 1.9 rocker questions
  13. #13 Re: 1.9 rocker questions
    g.a.
    we just came out of winter...
    its slow.
  14. #14 Re: 1.9 rocker questions
  15. #15 Re: 1.9 rocker questions
    g.a.
    ha.
    its slow.
  16. #16 Re: 1.9 rocker questions
    For sale
  17. #17 Re: 1.9 rocker questions
    GXP Level Member ryangtp89's Avatar
    Maine
    can't wait to get my 1.9 rockers and 105# springs installed!!! Right after installing them i gotta get my pcm tuned instead of keeping the crappy zzp 1.0 pcm.
    SLP headers, Wizaird cai, zzp1.0pcm ,slp powerflo catback, 3.4mps, NGK TR55's, 180*, zzp stage 1 hv tb,tb spacer, tb heatshield, Triple Edge Performance High performance Tranny, flipped motor mounts, spring blockers, prj 10.4mm wires, Sloted rotors & Ceramic brake pads,Alternator Voltage Booster. zzp 1.9 rockers & 105# springs
  18. #18 Re: 1.9 rocker questions
    Quote Originally Posted by ryangtp89 View Post
    GOOD MAN!!
  19. #19 Re: 1.9 rocker questions
    Maine
    Yeah i figure it's time to move away from the stone age.
  20. #20 Re: 1.9 rocker questions
    And the boom era
  1. 1.9 Rocker arms
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-07-2009, 03:07 PM
  2. rocker panel replacement??help??
    By brian91z34 in forum General Tech Discussion
    Last Post: 02-23-2009, 09:23 PM
  3. rocker panels
    By razoredge in forum Visual/Body Modifications
    Last Post: 11-27-2008, 07:50 PM
  4. Rocker rust
    By MichEE in forum Visual/Body Modifications
    Last Post: 09-10-2008, 11:28 AM
  5. 1.9 modded rocker install
    By ExpyGator in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 12:38 PM
