Thread: scan gauge
Results 1 to 5 of 5
  1. #1 scan gauge
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    My scan gauge wont turn on with my car, but if i unplug it and plug it back it will turn on. Then it only stays on a few seconds then turns off. anyone know whats wrong or how to fix it?
  2. #2 Re: scan gauge
    GTX Level Member blackflag's Avatar
    Virginia
    Power issues? did your car require the extra power line?
  3. #3 Re: scan gauge
    neeeds a 12 volt power source. Did it come with the little 3 wire harness?
  4. #4 Re: scan gauge
    Jan 2012
    Philadelphia
    mine has done that before its just a bad connection rly try and hold it there tightly see if it helps any
  5. #5 Re: scan gauge
    Pennsylvania
    You have a '97, so you have to run a power line. Did you do this?
    If the gauge is brand new, it is not set to scan yet. Hold both buttons to get the menu, then press the right button to select "SCAN."
  1. Just got a scan gauge, what do i need to look for?
    By blackflag in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2012, 08:25 PM
  2. interforce scan gauge
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 12-13-2011, 09:53 PM
  3. Scan Gauge II
    By Slick2500 in forum General Tech Discussion
    Last Post: 11-18-2011, 07:28 PM
