Thread: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
Results 1 to 7 of 7
  1. #1 ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    SE Level Member KevSorbo's Avatar
    Socal
    So I just got back from work and decided to change out the pulley since I got stuck this weekend. While all the others were a success. I got the info to turn clockwise to loosen the Tensioner pulley but now I'm stuck! I don't know how to get it off as it so tight on there. How do I get it off to swap for my new one and place the new one on.. This is the Alternator side w/Accessory Belt Side.
    Sorry, I'm not a mechanic but enjoy doing things myself. I felt a complete success as changing out all the other pulleys and belt this past weekend.
    I also did my own headers, exhaust, and suspension on my truck. I may take alot longer than most but I feel proud to try and complete a task...
    So anyone who can help me asap, thanks!
  2. #2 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    Socal
    So I got the bolt off the Tensioner Pulley trying to get the Tensioner to the right to release the belt. Is that right? Its really hard to do it as I can't seem to get it to budge at all. The other Tensioner Pulley on the Supercharger side was very easy to remove and install.
    Is there a trick I need to know about? Do you think my Tensioner would be completely out?
  3. #3 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    I dont understand why you are having so much trouble? You cant get the belt off? is that the problem?
  4. #4 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    Since you have changed the other pulleys, you know which way to turn the wrench. If it is stuck, spray a little WD40 or PB blaster on the bolt and let it set for a little bit. Only other advice I can offer is to put more ass into it.
  5. #5 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    Socal
    I got the bolt off with no issues. Once there, I'm stuck now in removing the belt and pulley. Any tips or guide?
    Yeah, I can't get the Alternator belt off the Tensioner Pulley. Any tips as it doesn't budge at all.
    Thanks
  6. #6 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    Nov 2008
    Eastern KY
    I am confused now as well
  7. #7 Re: ==> H@lp Asap, TENSIONER Pulley Removal & Install <==
    Socal
    ^I'll try to explain.
    This weekend I changed out the belt and tensioner pulley on the supercharger side with no issues. I got stuck on the Alternator Tensioner Pulley because I didn't know you had to loosen it up going clockwise. After some help on here I got the knowledge.
    I got off work today to use that knowledge. I loosened up the Tensioner Pulley on the Alternator side with no problems. A simple breaker pair go the bolt off. Thats where I'm stuck now.
    The dam Tensioner Pulley will not budge. I can't get it to move enough to loosen the Accessory (Alternator) Belt. I don't know if I'm doing it wrong.
    Hope that helps as I'm stuck and eating dinner now.
  1. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
  2. Please Read ASAP, Need all ur input asap
    By SteelCityTA in forum Off Topic Discussion
    Last Post: 03-29-2009, 02:41 AM
  3. --> Serpentine Belt & PULLEY Replacement Install H@lp <--
    By KevSorbo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 11:29 PM
  4. 60 V6 Engine Water Pump Removal And Install [*]
    By 19SE92 in forum How To Write-Ups/Tech Tips
    Last Post: 03-09-2008, 09:15 AM
  5. New tensioner from ZZP
    By IndeedSS in forum Off Topic Discussion
    Last Post: 01-22-2008, 08:31 PM
