Thread: antifreeze leak..
Results 1 to 12 of 12
  1. #1 antifreeze leak..
    SE Level Member bowtechguy's Avatar
    PA
    Just got a 1997 GTP and almost straight down from the SC nose, its dripping antifreeze! More dripps when cold. Temp is staying around 210. Water pump?? Would Bar's stop leak work??
    Thanks in advance!
  2. #2 Re: antifreeze leak..
    SE Level Member 04compggtp's Avatar
    Feb 2009
    new york
    Don't use that stuff. Just replace your water pump if its your problem. None of the stop leak stuff is good for your car and will not work for a water pump leak anyway.
    Thrasher cai, s&b 9",zzp stainless power log, zzp 3" cated dp, :180*t stat, autolite 104's, overkill pcm,: thrasher 3.4 modular pulley,F&R drilled/slotted rotors. 245/45/18 Fierce on Casino's
  3. #3 Re: antifreeze leak..
    PA
    I think as soon as I get a maunal for it, I'll tear into it n see where its leaking.
  4. #4 Re: antifreeze leak..
    TDCRacing
    Guest
    Sounds like it may be you're plastic coolant elbow's
  5. #5 Re: antifreeze leak..
    PA
    Hard to change?
  6. #6 Re: antifreeze leak..
    Barksdale AFB, LA
    2009 Subaru Impreza WRX STI
  7. #7 Re: antifreeze leak..
    SE Level Member xawahl's Avatar
    Jan 2009
    Louisville KY
    I had the same problem...look and see if coolant is spraying on the firewall...and collecting below the water pump...Sounds like its a water pump...not to bad to do at all, and the part was cheap.
    1998 2dr GTP- 81k miles, light mods, fun DD.
    1992 BMW 325i- the eternal Project
  8. #8 Re: antifreeze leak..
    PA
    Yes thats exactily what my car is doing! looks like I know what I'll be doing this weekend.
  9. #9 Re: antifreeze leak..
    PA
    Sabrewings, the link you posted didn't work.
  10. #10 Re: antifreeze leak..
    Barksdale AFB, LA
    Quote Originally Posted by bowtechguy View Post
    Works for me. I even deleted all my NAIOA cookies so I was no longer logged in as a member and it still works.
  11. #11 Re: antifreeze leak..
    PA
    For me it asks for a nickname and password. Still, thanks!
  12. #12 Re: antifreeze leak..
    Barksdale AFB, LA
    Maybe our admin is messing with what parts of the site unregistered users can and can't access.
    Either way, it's a guide to replacing the coolant elbows. Might be worth registering to look at.
  1. Antifreeze leak...
    By bowtechguy in forum General Tech Discussion
    Last Post: 03-23-2009, 07:24 AM
  2. oil leak
    By whitegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 03:48 AM
  3. Smelling antifreeze
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-08-2008, 11:06 PM
  4. Leaking Antifreeze
    By GTPluv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 08:13 PM
  5. Oil leak
    By fiveinthelive in forum General Tech Discussion
    Last Post: 03-11-2008, 09:35 AM
