If it's knocking that much at the shift, you either have something hitting something else or the knock sensors are picking up the sounds of the clutch packs in the transmission. Only way to fix the second part is dynamat between the transmission case and the rear knock sensor.
I'm running mostly DHP file transmission settings and barely get a 0.5* blip at a shift.
