Thread: Air 2 Air M90 Intercooler Adapter Plate
Results 41 to 60 of 65
  1. #1 Re: Air 2 Air M90 Intercooler Adapter Plate
    GT Level Member Merlin's Avatar
    May 2008
    Broken Arrow, OK
    I would love to see an a/a intercooler, but im not sure how you would make it out of phelonic, do yo uplan on amking it in a few pieces?
    you could go and take the neck design off of the front of the fit plate and replicate it on the back, having both of the inlet an outlet facing forward.
    drop the pipes towards the front and run the intercooler that way. it would be shorter than the fit setup on the ecotec engines.
    Engineering the impossible.
  2. #2 Re: Air 2 Air M90 Intercooler Adapter Plate
    Donating Users blowfishRus6's Avatar
    g.a.
    ah, i tried
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #3 Re: Air 2 Air M90 Intercooler Adapter Plate
    id love to see it done, but i dont have the funds to try it.
  4. #4 Re: Air 2 Air M90 Intercooler Adapter Plate
    Feb 2008
    ^^ Ditto. I would absolutely love to see one made for our cars!
  5. #5 Re: Air 2 Air M90 Intercooler Adapter Plate
    seriously, if i were to decide that this car was my project car then i would have at it. that is not that case because it is a FWD V6.
    i am looking towards RWD and/or AWD with a turbo in the near future.
  6. #6 Re: Air 2 Air M90 Intercooler Adapter Plate
    Poppin 'em thangs mechguy's Avatar
    Dec 2010
    Canada
    Reviving a really old thread here......
    Did somebody actually make one of these? It's not something I would purchase now, but maybe in the future. I'm very interested to know if this was developed/built.
  7. #7 Re: Air 2 Air M90 Intercooler Adapter Plate
    in Australia perhaps.
  8. #8 Re: Air 2 Air M90 Intercooler Adapter Plate
    GTX Level Member Juanmiguel's Avatar
    Mexico
    I think it's cool, but what would be the benefits from A2A over W2A? would it be cheaper or more efficient?
  9. #9 Re: Air 2 Air M90 Intercooler Adapter Plate
    Quote Originally Posted by Juanmiguel View Post
    cheaper? probably, air to air intercoolers are cheap.
    more effective? nope. water to air is more effective.
    you'd also have major tuning problems and would be forced to tune speed density with no MAF.
  10. #10 Re: Air 2 Air M90 Intercooler Adapter Plate
    Michigain
    They've been made, I've seen a few photo's of them, but I dont know tons of info on them. But I belive they are all produced in Australia. It would not be worth the time to mess with one. By the time you get one into the states I'm going to guess it'd be cheaper to buy a full size water to air intercooler and you'd see much greater gains. That's not counting the custom work you'd have to do rework the air to air system to make it work on a w-body.
    Edit, Holy Crap I'm blind just noticed this was a 3 page thread. Everything I've already covered has been said in the two other pages I just noticed. haha
    With that being said, more power to you if your all about building your own set up. But I dont see much point in it when the intercoolers that you can buy now are great to start with.
    1998 Caged \ Drag GTP = Demoded & Sold
    1999 Caged \ Stattam Turboed GTP hunting for Low 10's
    2008 TrailBlazer SS AWD LS2 400 H.P
  11. #11 Re: Air 2 Air M90 Intercooler Adapter Plate
    Jersey
    air to air is what i see holden guys using but, you have to remember their motors aren't sideways either.
    16' wrx sti- stock
  12. #12 Re: Air 2 Air M90 Intercooler Adapter Plate
    Dec 2010
    Canada
    I know that this was built in Australia, but I was wondering if the GPF member had produced his own.
    For me, the single loop system offers advantages, or peace of mind if you will, because if the W2A unit leaks it will kill your engine. Throw a big enough FMIC on the car and the intake charge will be at near ambient temps.
    Lag would be a disadvantage as everybody has mentioned, but it shouldn't be nearly as bad as a turbo.
  13. #13 Re: Air 2 Air M90 Intercooler Adapter Plate
    Michigain
    Quote Originally Posted by mechguy View Post
    If your worryed about a leak or a failed intercooler pump why not look into a aeroforce scan gauge? That'd be a hell fire way to keep tab's on knock. If you see a large jump in knock at wot. (IMO any knock) then it's pretty much a no doubt issue that somthing is going on with that car that shouldnt be. Let it be a failed i\c system or some one put cheap gas in the car.
  14. #14 Re: Air 2 Air M90 Intercooler Adapter Plate
    Dec 2010
    Canada
    Quote Originally Posted by Red Devil View Post
    If the manifold mounted heat exchanger bursts/breaks/etc and pisses its fluid into the intake, how would the gauge help?
  15. #15 Re: Air 2 Air M90 Intercooler Adapter Plate
    Michigain
    Right, because that happens all the time. If something makes it past the filter, into the t.b, around and around in the blower and then comes out of the blower with such amazing force that even chuck Norris won't stand a chance and destroys your intercooler which then allows half a gallon of water or coolant into your intake it'd be screwed. I think at that point more then enough hell has rained down on to the car that worrying about having a dicked short block as well is not such a big deal. Ive yet to see a damaged ic core in the last 8 years I've been around, so I find this not likely to happen, but I'd like to be proved wrong. So you can tell me Im a retard.
  16. #16 Re: Air 2 Air M90 Intercooler Adapter Plate
    no need to get your panties in a bunch.
  17. #17 Re: Air 2 Air M90 Intercooler Adapter Plate
    Dec 2010
    Canada
    Well, I don't agree with throwing the word "retard" around.
    Have you ever heard of thermal stress? Nobody is worried about the intake sucking in a pigeon and blowing up the engine, by the way. Where I live, the temperature is -26C right now. That presents a huge thermal gradient when the engine begins warming up. That accounts for most of my concern when running the W2A units. It sounds as though most people have excellent reliability with W2A, so there should be nothing to worry about.
    Happy intercooling.
  18. #18 Re: Air 2 Air M90 Intercooler Adapter Plate
    Jersey
    ^ by the time it takes to realize whats going on the engine is done anyways
    16' wrx sti- stock
  19. #19 Re: Air 2 Air M90 Intercooler Adapter Plate
    Dec 2010
    Canada
    Quote Originally Posted by 99prixgt View Post
    Exactly. It would be like driving the car into a lake and checking the scan gauge as the engine is going underwater.
  20. #20 Re: Air 2 Air M90 Intercooler Adapter Plate
    Charles City, IA
    If you are going to take the time to make an air to air for the m90, just turbo the *****.
    SMGPFC Two Nipple General
  1. N* TB adapter plate
    By DanGTP in forum General Tech Discussion
    Last Post: 05-23-2008, 10:47 AM
