Thread: Coolant leak below supercharger
Results 1 to 4 of 4
  1. #1 Coolant leak below supercharger
    Nov 2008
    Toronto Canada
    Anyone have a similar problem to this. I have coolant under the supercharger but can not see the leak. Any ideas? Its a slow leak builds up and runs on to exhaust manifold. Posted this message before I pull it all apart. Replys appreciated.
  2. #2 Re: Coolant leak below supercharger
    Ohio
    Pictures or a better description may be helpful. Its probably your lower intake manifold gaskets.
    00 GTP demodded and forsale
  3. #3 Re: Coolant leak below supercharger
    Bastard Reptile's Avatar
    Kansas City, MO
    Sounds like you're in need of the classic Lower Manifold Gaskets and coolant elbows.
  4. #4 Re: Coolant leak below supercharger
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    ^^^x2 replace your LIM gaskets, and make sure to replace them with the metal gaskets not the crappy plastic ones.
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  1. suspected coolant leak into oil
    By e56505 in forum General Tech Discussion
    Last Post: 02-16-2009, 03:18 PM
  2. Most likely source for coolant leak?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:09 AM
  3. Help with coolant leak
    By eagleeyes9 in forum General Tech Discussion
    Last Post: 12-09-2008, 04:45 PM
  4. Coolant Leak
    By TheOtherNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 02:56 PM
  5. Coolant leak
    By jdgaetan in forum General Tech Discussion
    Last Post: 05-31-2008, 03:24 AM
