Thread: N* throttle body
Results 1 to 6 of 6
  1. #1 N* throttle body
    Jersey
    I want to put a N* throttle body on my gen v. I was going to go to the junkyard to purchase it. Anyone know what else I would need with the throttle body besides the adapter plate in order to hook it up properly?
    16' wrx sti- stock
  2. #2 Re: N* throttle body
    the TPS converter thing (5 wire to 3 wire). pretty sure everything else just plugs in.
  3. #3 Re: N* throttle body
    Jersey
    Is the throttle cable bracket the same? Or is it modded to work with our cars?
    16' wrx sti- stock
  4. #4 Re: N* throttle body
    depends which one you get. the 3 bolt N* has a crappy crappy bracket that youll have to try and modify on your own or make your own for it to work well. the newer ones you can buy a bracket that is already modified from ZZP. do you have your blower inlet opened up to match the N* already? youre going to need to do that otherwise there will be a big step the air has to take.
    i got rid of my N* after a few days of having it because i didnt like the throttle feel. our throttle isnt linear, it actually opens more the more you push down the pedal. the N* makes it linear which is why people say they have "better" throttle response.
  5. #5 Re: N* throttle body
    Jersey
    From what ive read alot of guys are bolting up N*'s with their gen v, claiming a perfect match, without porting the inlet and claiming more power and that better throttle response.
    16' wrx sti- stock
  6. #6 Re: N* throttle body
    yeah, that is because a genV has a 75mm inlet. i was figuring you were talking genIII here.
  1. LS1 or N* Throttle Body
    By 2000GTP2708 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2012, 08:19 AM
  2. LS1 Throttle body
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 05:16 PM
  3. throttle body screen
    Last Post: 11-08-2008, 08:46 PM
  4. HV throttle body for the L36
    By GP2003GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-02-2008, 05:34 AM
