You may wanna double check but I believe the oil pan and pick up are different on the H bodies verses the Ws.
If the pulley ain't a 3.8", Then its been tampered with before....
the bonneville has the same pulley as the rest of the 3.8's
its dependent on the year of the car, but 96-99 and00-03 Bonneville l67's have small differences
you will need to change the oil pan, coil pack bracket and the tensioner bracket from the SSEi motor. You will also need to add your dog bone mounts onto the motor
