Thread: Occasionally Sputtering then back to normal? Help
Results 1 to 9 of 9
  1. #1 Re: Occasionally Sputtering then back to normal? Help
    Jan 1970
    Maquoketa, Iowa
    Is it similar to when you unplug the maf sensor and try and run it, or could you unplug the maf sensor now and see if it runs the same way?
    Anyway you can get a scan posted up when it does it/low idle? Could it be the rear 02 sensor sim.? Mine went out and will cause the rpms at low idle sometimes they will rock the rpms back and forth from very low rpms to about 1200 rpms, back and forth...
  2. #2 Re: Occasionally Sputtering then back to normal? Help
    Odessa, MO
    Quote Originally Posted by FoSHO99 View Post
    I'll try unplugging the MAF tomorrow. Rear O2 sensor is non-existant and it is turned off in the PCM, been that way for a few years.
  3. #3 Re: Occasionally Sputtering then back to normal? Help
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by Abrasive View Post
    Well, that might be your problem, they say on most 01+years the rear 02 just can't be deleted from the pcm. On my 01, i tried deleting the codes and still had the problem.
    Read through this and see if it might be the issue:
    http://www.grandprixforums.net/f65/r...ewer-7092.html
  1. sputtering problem
    By Risinnfallen in forum General Tech Discussion
    Last Post: 01-07-2011, 06:00 PM
  2. 96 GPSE 3100 spitting,sputtering,and backfiring
    By 96gpse in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-21-2009, 09:46 PM
  3. Normal coolant temp?
    By nboylie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 08:46 PM
  4. sputtering in the upper rpms?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-06-2008, 04:36 AM
  5. Pictures.. engine look normal?
    By golden_c_ninja in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-04-2008, 07:21 PM
