Been working on this for a couple months now to install soon and do some real world testing. Myself and a couple engineers from work have done every type of bench testing we could think up including building my own mock up m90 and whatnot. I've also been working with BiggRiggs, he knows his sh*t haha. He pretty much worked with me through pm's every step of the way so he knows exactly what i'm up to with this little setup and another one i have in the works for later on in the season.
Post blower FTW, this way it has an actual inter-cooling effect instead of just raising the octane like pretty much every setup i've seen on the m90 apps including my own, so i'm not pointing fingers. Pre-blower just isn't efficient, so it DOES matter where the location is. All the gains you guys have seen is because of the meth not the water. Riggs can explain this into much further detail since, like i said, knows his sh*t.
My setup is 2 d03 nozzles (Not exactly sure they're called "do3" but they're 3gph)
AIS pump/reservoir with 150psi pump
boost activated at 6psi
Plastic tubing from AIS
Check valves... We'll see, i have a couple extra nitrous fuel solenoids laying around and believe that to be better IMO. It's another little idea i have, biggriggs i'll pm you when i get a chance to run that past you BTW. I just don't like check valves especially in my app since neither will ever crack at the exact same pressure causing chaos in my LIM.![]()
