Thread: Pcm info. Whats the best choice?
Results 1 to 20 of 23
  1. #1 Pcm info. Whats the best choice?
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    I have a 98 gtp. It has a 3.4 pulley, 3" catless downpipe, no ubend, 3" exhaust split to 2.5" turbo mufflers, fwi, 180* stat, 8 mm wires, al 104's, crankcase breather, (soon to come: Headers). What is the best pcm to get for this car? I hear good and bad things about the zzp 1.0, i want something economical of course and that works how its supposed to. So i just wanted to get some advice.
    Thanks.
  2. #2 Re: Pcm info. Whats the best choice?
    GT Level Member DnaProdigy's Avatar
    Jul 2008
    New York
    Quote Originally Posted by a98gtp4u View Post
    Thanks.
    Where have you heard good things about ZZP beside from zzp? :P
    All i hear about ZZP's pcms are how bad they are.
    Overkill PCM's are good, Intense and i believe reptile does them (not sure).
    You'd get a more in depth response here.
    2006 Grand Prix GXP
  3. #3 Re: Pcm info. Whats the best choice?
    GEORGIA
    Cool, thanks. Ill check them out.
  4. #4 Re: Pcm info. Whats the best choice?
    GEORGIA
    Is there a specific website or is it just overkill.com?
  5. #5 Re: Pcm info. Whats the best choice?
    Jul 2008
    New York
    His site. :: Overkill Motorsports ::
    His email. willoverkill@gmail.com
    2006 Grand Prix GXP
  6. #6 Re: Pcm info. Whats the best choice?
    GEORGIA
    Ok, thanks man.
  7. #7 Re: Pcm info. Whats the best choice?
    Jul 2008
    New York
    Ok, thanks man.
    NP, actually stumbled on this too.
    http://www.grandprixforums.net/f65/i...ill-18630.html
    2006 Grand Prix GXP
  8. #8 Re: Pcm info. Whats the best choice?
    3800performance.com still sells the best mail order PCM for the 3800.
    DHP 1.0 PCM.
    Get it...nothing else.
  9. #9 Re: Pcm info. Whats the best choice?
    Jersey
    Thanks.
    why are you running a breather?
    16' wrx sti- stock
  10. #10 Re: Pcm info. Whats the best choice?
    GEORGIA
    I just thought it looked good. It hasnt caused any problems or anything. Y? Should i remove it? Engines been running a bit cooler since i put it on. Also on these pcm's, did any of u have to do the case learn?
  11. #11 Re: Pcm info. Whats the best choice?
    Jersey
    Yes, a case lean needs to be done. Get rid of that breather, all its doing is causing a huge vacuum leak. You only want to run a breather if your pcv is blocked, for example some intercoolers block the pcv.
    16' wrx sti- stock
  12. #12 Re: Pcm info. Whats the best choice?
    GEORGIA
    Ive been reading up on he breather and all i get is that it doesnt cause a vacuum leak, it relieves the motor of positive crankcase pressure, gasses that get past the piston rings. It hasnt triggered any codes and the car actually runs cooler and responds better so ima use it for a little longer and see how it does. Thanks for the info tho.
  13. #13 Re: Pcm info. Whats the best choice?
    Jul 2008
    New York
    Quote Originally Posted by 99prixgt View Post
    The pressure just recirculates into the intake anyway doesn't it? With a breather it would escape into the environment.
    How does this cause problems? ( i am not to knowledgeable on this particular subject hence my curiosity)
    2006 Grand Prix GXP
  14. #14 Re: Pcm info. Whats the best choice?
    GEORGIA
    Thats what im saying. It shouldnt. All it does is vent those gasses relieving he pressure in the crankcase.
  15. #15 Re: Pcm info. Whats the best choice?
    Jersey
    ^wrong...
    Quote Originally Posted by DnaProdigy View Post
    First off all air is metered. Adding a breather to your car with a functioning pcv, lets air out making you have lack of vacuum pressure a.k.a Big mother vacuum leak. On a side note, your car can possibly go lean with a breather...I try to avoid them like the plaque.
    When I did my gen5 swap, I modified my adapter plate for my N* so i didn't have to run a breather.
    16' wrx sti- stock
  16. #16 Re: Pcm info. Whats the best choice?
    GEORGIA
    Well then maybe itll even me out cause i know im runnin rich as hell when i got a catless downpipe.
  17. #17 Re: Pcm info. Whats the best choice?
    Jersey
    no your engine is running the same. Now you can smell the gas, since your cat-less.
    16' wrx sti- stock
  18. #18 Re: Pcm info. Whats the best choice?
    So anyways...
    Get a DHP.
  19. #19 Re: Pcm info. Whats the best choice?
    Jul 2008
    New York
    Ah gotcha, tnx!
    2006 Grand Prix GXP
  20. #20 Re: Pcm info. Whats the best choice?
    Indianapolis
    i got a zzp and have never had any problems with it
  1. Top Swap Info and Faqs, Also lots of 3800 Info
    By 02BlueGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2024, 11:56 PM
  2. Drink of choice?
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 11-21-2010, 08:54 PM
  3. Whats everyones tool of choice...
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 07-30-2009, 10:52 AM
  4. my possible wheel choice
    By BringTheRain in forum Tires & Wheels
    Last Post: 01-25-2008, 02:03 AM
