TDCRacing
I don't see how any gasket or the wrong TQ sequence could cause a leak when you were building up compression by turning the motor. Now maybe when it was running or turning at a higher speed. I mean something would have to be way off for it to loose compression when you were just turning it like that.
You can bring the heads to a machine sop and get the bottom of the heads resurfaced. They usually take like .010 off to ensure flatness.
You may as well get a good set of roller rockers for the price of the modded. I noticed ZZP had added a 50.00 deposit. Wich makes them almost the cost of some Yella terra roller rockers.
As for getting the gasket off i would use a wire brush on a drill and be real carefull around the cylinders.Make sure you clean everything EXTRA good.
You'll need to take it to the machine shop if you get bigger valves. And don't get the valves with the undercut stems. They have a reputation for breaking.
