Quote Originally Posted by comongoose View Post
the noise was definitely coming from the LIM, but I also heard a little bit of mysterious crackling noise as well from who knows where. This was all during the compression stroke. I do have L67 intake and heads on the L26 block. I could get the leak-down tester from harbor freight for 35 bucks but I m not sure how to use it, where do you put the compressed air? Also just so you know I also had torqued the heads down in the wrong pattern, I accidently used the smaller v6 motor pattern. I don't know if this has anything to do with it or how specific the pattern is. I noticed on the top swap write up sticky they have a slightly different pattern that what is seen on autozone's repair manual write up as well. I might have also not have cleaned the block as well as I should. A buddy and I stood there for almost 2 hours scrapping it with a razor blade and got all the gasket off but the black underlay wouldn't come off. Maybe that is part of the problem. When I wanted to take the baked off gasket on my TB I used 1200 grit wet sand paper, is this safe on the block and heads as well? Should I look into a shop that will clean the bottom of my heads?
Now that I am no longer in a rush for this car, I think I might add some light performance as well. I was looking at getting modded 1.9 rocker arms and maybe springs. If I get larger valves from WBS can I lap them to the heads? Also will these do any performance for me if they are not ported? The valves look pretty haggard so I was thinking maybes new valves would be a good idea? I want to get this all right in one shot since its getting kind of expensive having to keep buying 60 gaskets.
I don't see how any gasket or the wrong TQ sequence could cause a leak when you were building up compression by turning the motor. Now maybe when it was running or turning at a higher speed. I mean something would have to be way off for it to loose compression when you were just turning it like that.
You can bring the heads to a machine sop and get the bottom of the heads resurfaced. They usually take like .010 off to ensure flatness.
You may as well get a good set of roller rockers for the price of the modded. I noticed ZZP had added a 50.00 deposit. Wich makes them almost the cost of some Yella terra roller rockers.
As for getting the gasket off i would use a wire brush on a drill and be real carefull around the cylinders.Make sure you clean everything EXTRA good.
You'll need to take it to the machine shop if you get bigger valves. And don't get the valves with the undercut stems. They have a reputation for breaking.
