This raises suspicion. Often times when a large component is removed and replaced, grounds get forgotten, wires get pinched or pulled and connectors get crushed.
You also say:
Makes me wonder if you're missing a connection to the MAP sensor. Vacuum or wiring.If I put the pedal to the metal then the things I said will come
