Thread: Overheat issue
Results 1 to 6 of 6
  1. #1 Overheat issue
    SE Level Member Garandpa's Avatar
    Oct 2016
    Davisburg, MI
    On the way home from church yesterday the A/C was struggling to keep up and we overheated. This is in Florida, and it was warm yesterday, around 85 degrees. The fans seem to be running as advertised, and there is coolant in the overflow bottle. What else should I check?
  2. #2 Re: Overheat issue
    Mar 2014
    Tucson
    Check the amount of coolant in the radiator.
    When cold.
  3. #3 Re: Overheat issue
    Oct 2016
    Davisburg, MI
    Quote Originally Posted by BrandonHall10 View Post
    When cold.
    The fluid level is about 8" below the cap
  4. #4 Re: Overheat issue
    Mar 2014
    Tucson
    Quote Originally Posted by Garandpa View Post
    Top it off brother.
  5. #5 Re: Overheat issue
    Oct 2016
    Davisburg, MI
    Top it off brother.
    I did, and also changed the thermostat. Running beautifully now, thanks guys!
  6. #6 Re: Overheat issue
    Apr 2014
    commerce twp,mi
    ya might want to pull that coolant tank off and flush it out.
    08 grand prix NA3800
  1. GM 3400 overheat
    By wa9zug in forum 3.4L V6 (LQ1) DOHC
    Last Post: 11-16-2014, 03:41 PM
  2. Overheat, Low boost
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2011, 11:29 PM
  3. Overheat & Stall, What is next?
    By mojonba in forum Engine
    Last Post: 01-30-2011, 10:00 PM
  4. begining to overheat
    By mezzoni in forum General Tech Discussion
    Last Post: 10-29-2010, 07:10 AM
  5. 3.1 overheat
    By basmatic in forum General Tech Discussion
    Last Post: 03-08-2010, 05:07 PM
