Thread: Running Rich 04 GTP
Results 1 to 6 of 6
  1. #1 Re: Running Rich 04 GTP
    hangover park IL
    and it wont damage the cat. the PCM is correcting the hardwritten tables by removing fuel (it will go to 44% change after it hits the 22% "wall" for long enough) to keep the mixture at stoiciometric.
    keep in mind that the TPC/MAP(and baro)/MAF and O2 are "trusted" sensors, so the pcm ASSuMEs they are correct even when they may be skewed by age/contamination.
    the O2 is the primary datapoint for trims....so make sure its good.
    ~James~ Psychotic Gearhead
  2. #2 Re: Running Rich 04 GTP
    May 2021
    Melbourne Fl
    Thanks for the advise. It's all AC Delco sensors with NGK plugs on a stock tune. It was running rich before and after the sensors were replaced so I don't think it's related to one of the sensors. I didn't notice any exhaust leaks but I'm going to pull the front P log and inspect it for any cracks since those were a bit notorious for cracking at the welds.
  1. 2000 GTP Running Rich
    By addeible in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2013, 12:27 PM
  2. Running too rich?
    By 94GrandPrixSE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-18-2013, 09:43 AM
  3. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. car running really rich
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2009, 04:48 PM
