Originally Posted by GTPpower L67 bottom end? You're going to need new pistons to increase the compression. Just keep in mind, 500whp is basically impossible. The compressor doesn't flow enough. 500 is the goal on turbo. id be happy to see 380 on the m90. Unless thats what you meant.
Originally Posted by 04lss 500 is the goal on turbo. id be happy to see 380 on the m90. Unless thats what you meant. I should note realistically, i expect 350 to the wheels on the m90 with a 2.5 pulley, meth, e85, ic and the xpz cam.
Forum Rules
