Thread: Mounting Pump and tank for meth injection.
Results 1 to 12 of 12
chrisrexmandie Mounting Pump and tank for... 09-14-2020, 05:22 PM
SgtMarshal Re: Mounting Pump and tank... 09-14-2020, 05:41 PM
chrisrexmandie Re: Mounting Pump and tank... 09-14-2020, 06:47 PM
SgtMarshal Re: Mounting Pump and tank... 09-14-2020, 07:19 PM
chrisrexmandie Re: Mounting Pump and tank... 09-14-2020, 07:21 PM
Scottydoggs Re: Mounting Pump and tank... 09-14-2020, 07:22 PM
Scottydoggs Re: Mounting Pump and tank... 09-14-2020, 07:23 PM
chrisrexmandie Re: Mounting Pump and tank... 09-14-2020, 08:01 PM
Scottydoggs Re: Mounting Pump and tank... 09-14-2020, 08:18 PM
SgtMarshal Re: Mounting Pump and tank... 09-14-2020, 08:13 PM
chrisrexmandie Re: Mounting Pump and tank... 09-14-2020, 08:22 PM
Scottydoggs Re: Mounting Pump and tank... 09-14-2020, 08:27 PM
  1. #1 Mounting Pump and tank for meth injection.
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    How have you guys mounted your tanks and pumps for a meth injection kit? I am thinking about doing it in the trunk. If anyone could post some pictures that would help a lot.
  2. #2 Re: Mounting Pump and tank for meth injection.
    Kemmerer, Wyoming
    I mounted my tank in the trunk. I placed it on the hump of the wheel well. you can't go so far forward that you wont be able to fill the tank, but too far back and your mounting bolts will go through the rear quarter panel. You also need to make sure the tank is level. I put the pump right behind the tank. let me see if I have any pictures on my google drive.
    I couldn't find any pictures. I don't remember where I saved them.
  3. #3 Re: Mounting Pump and tank for meth injection.
    Sep 2018
    NC
    is the hump for the wheel well flat enough to mount it easily I dont have any means to make brackets
  4. #4 Re: Mounting Pump and tank for meth injection.
    Kemmerer, Wyoming
    ya it was. I ended up using a long transmission funnel to fill my reservoir. the only thing I regret about installing it is that I forgot to check the level.
  5. #5 Re: Mounting Pump and tank for meth injection.
    Sep 2018
    NC
    do you not have a low level sensor?
  6. #6 Re: Mounting Pump and tank for meth injection.
    i got 3 bolts in. pumps bolted to the floor. you have full access under the trunk there.
    Mounting Pump and tank for meth injection.-135-jpg
    Mounting Pump and tank for meth injection. Attached Images
  7. #7 Re: Mounting Pump and tank for meth injection.
    yes you need a funnel to fill it up. but it works.
  8. #8 Re: Mounting Pump and tank for meth injection.
    Sep 2018
    NC
    did you use self tapping screws or something like a riv-nut?
  9. #9 Re: Mounting Pump and tank for meth injection.
    Quote Originally Posted by chrisrexmandie View Post
    same as marshal, the aem kit has everything you need. i drilled and nut and bolted every thing down with supplied hardware.
  10. #10 Re: Mounting Pump and tank for meth injection.
    Kemmerer, Wyoming
    the kit I bought came with bolts and nuts, and spacers. aem progressive.
  11. #11 Re: Mounting Pump and tank for meth injection.
    Sep 2018
    NC
    does water get thru the holes you drilled?
  12. #12 Re: Mounting Pump and tank for meth injection.
    not that i ever seen, i used the washers provided as well.
  1. WTB: Meth Injection KIT
    By fri3dchick3n in forum Wanted To Buy - Parts
    Last Post: 03-01-2013, 04:48 PM
  2. Meth Injection Kit
    By 01GrandPrixTURBOGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2012, 12:41 AM
  3. DIY Meth injection ?'s
    By TEK310 in forum General Tech Discussion
    Last Post: 06-23-2012, 01:23 PM
