If the GTP is the same routing as the GT then check the steel fuel lines as they route up against the drivers side firewall. There is insulation there and the lines are clipped in right against it which leads to rust. Also brake lines in that area. I've replaced 2 brake lines due to this design.
I'd carry a fire extinguisher in the car at this point. That sounds like a fire just waiting to happen.
