Thread: Crank Seal Removal
Results 1 to 4 of 4
  1. #1 Crank Seal Removal
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    What's the best way to remove the crank seal? Is it as primitive as bashing it in like the trans-axle seal? Or do I need a special tool?
    2000 GTP 4DR - Stock
    243,000 miles
    CHICAGO, IL
    My Car: http://www.grandprixforums.com/members-rides/103740-lukes-gtp.html#post1443981
  2. #2 Re: Crank Seal Removal
    trans axle seal method.
  3. #3 Re: Crank Seal Removal
    Nov 2011
    NY
    Just use a seal puller thingy... Lol
  4. #4 Re: Crank Seal Removal
    Dec 2015
    Chicago, IL
    Thanks for the recommendations guys. With the front cover off I’m going to try at pop it out, hitting it from the back.
    Looks like the ZZP extra thick gasket turned into mush. On a different forum, James said he uses an OEM gasket sandwiched with a FelPro gasket to get that extra thick clearance needed for the double-roller setup. What have guys been using other than the ZZP extra thick gasket? The replacement gasket I bought is the very same ZZP gasket, at it looks janky right out of the box. I will post up some pics later today.
  1. Some Questions About Replacing the Front Crank Seal
    By Kaiser Pontiac in forum General Grand Prix Discussion
    Last Post: 06-04-2021, 06:06 AM
  2. Oil everywhere. Crank seal? Under Supercharger, LIM?
    By Hexadecimus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-12-2015, 09:51 PM
  3. Bad crank seal?
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2013, 09:32 PM
  4. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
  5. Front Crank seal Leak!
    By Soeasytobefake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:39 PM
