Thread: Oil everywhere. Crank seal? Under Supercharger, LIM?
Results 1 to 4 of 4
  1. #1 Oil everywhere. Crank seal? Under Supercharger, LIM?
    Jun 2015
    USA
    I picked up a rough but driving 97 GTP with 170k miles as a project/parts car, and there is oil ALL over this *#$#*&.
    1. The engine bay was a light gray rather than white on the crank side, which I'm guessing was the S/C or more likely the crankshaft pulley slinging oil.
    Do I need to pull the engine to change that seal? If not, is it worth it for ease of access? That would be a pretty big DIY job.
    2. There's oil around the S/C sitting in the pockets of the intake plenum. Is this likely from the LIM gasket? What else might cause it?
    Thanks
  2. #2 Re: Oil everywhere. Crank seal? Under Supercharger, LIM?
    needs lim gaskets for sure. valve cover gaskets as well.
    check the oil pressure sensor, they are known to fail, when they do they leak oil fast. its in the oil filter housing, pass side of the car, a few inches from the oil filter.
    and 3 cans of de greaser would be a good idea. clean it up best you can.
  3. #3 Re: Oil everywhere. Crank seal? Under Supercharger, LIM?
    Jun 2015
    USA
    Thanks, I'll look at the oil pressure sensor too. Can the threads be sealed or will the sensor need to be replaced?
    3 cans of degreaser won't touch this. Maybe 3 gallons of simple green and a pressure washer!
  4. #4 Re: Oil everywhere. Crank seal? Under Supercharger, LIM?
    this looked clean from the top. but its a grease ball under it all lol
    the o/p sensor has tapered threads, npt. so they get fatter, the new sensor had sealant on it, once your in the sealant, and its snug feeling stop, or you can crack the housing.
    oil leaks out the plug, so if the plug end is wet its leaking for sure.
  1. Bad crank seal?
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-20-2013, 09:32 PM
  2. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  3. Oil Pan Gasket, Crank Seal/Timing cover.
    By Nowak1981 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2011, 02:48 PM
  4. New Front Crank Oil Seal Leaking - Grooved Balancer?
    By Scott Kane in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 03:58 PM
  5. Front Crank seal Leak!
    By Soeasytobefake in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2010, 11:39 PM
