I dunno anything about going by E85 stoich values. Did you adjust the other tables to same stoich? But I think you should take your timing way down before and work on your fuel, then slowly bring timing in. If you use that guide i linked i bet you get your trims locked in at 0 wot. But yeah, being too rich can cause knock. You don't want to enter PE and be adding or subtracting fuel.
