Thread: Crankshaft position sensor 06 GP 3.8 SC
Results 1 to 11 of 11
  1. #1 Crankshaft position sensor 06 GP 3.8 SC
    Jan 2016
    Tucson, AZ
    Do I need to remove the harmonic balancer to get to the crankshaft position sensor?
  2. #2 Re: Crankshaft position sensor 06 GP 3.8 SC
    GT Level Member mguzzo's Avatar
    Buffalo NY
    yes
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Crankshaft position sensor 06 GP 3.8 SC
    Jan 2016
    Tucson, AZ
  4. #4 Re: Crankshaft position sensor 06 GP 3.8 SC
    You'll need M6 x 1.0 bolts to do it too.
  5. #5 Re: Crankshaft position sensor 06 GP 3.8 SC
    Oct 2014
    portland oregon
    Not as bad as it seems
    Sent from my SM-N920V using Tapatalk
  6. #6 Re: Crankshaft position sensor 06 GP 3.8 SC
    GTP Level Member
    Oct 2014
    It’s easy with the right bolts.
  7. #7 Re: Crankshaft position sensor 06 GP 3.8 SC
    Apr 2015
    Columbus, OH
    Easy getting off, not as fun torquing it down to specs on jack stands.
    Top Swapped 01 Imp
  8. #8 Re: Crankshaft position sensor 06 GP 3.8 SC
    Jan 2016
    Tucson, AZ
    Thanks for your input guys. Definitely appreciated.
  9. #9 Re: Crankshaft position sensor 06 GP 3.8 SC
    FWIW Im pretty sure if you search on "Easy" and my SN you'll find a how to on it. It'll list the tools etc. If you have air, you'll be done in under 15 min.
  10. #10 Re: Crankshaft position sensor 06 GP 3.8 SC
    St. Louis
    I will add this (in case its not in Bill's how-to)- Make sure you line up the crankshaft key and the balancer BEFORE you reinstall it with an impact. It shoud go on by hand a bit so you know it's lined up. If not then you might not have a great day.
  11. #11 Re: Crankshaft position sensor 06 GP 3.8 SC
    Jan 2016
    Tucson, AZ
    You guys are awesome! You’ve saved me hundreds of $$$ over the years. Thank You.
  1. Crankshaft position sensor
    By xcwilli11 in forum General Tech Discussion
    Last Post: 03-15-2015, 11:16 PM
  2. Crankshaft Position Sensor
    By hollilynn in forum General Tech Discussion
    Last Post: 02-05-2014, 07:51 PM
  3. Crankshaft Position Sensor
    By pheasant plucker in forum General Tech Discussion
    Last Post: 12-29-2012, 02:18 PM
  4. crankshaft position sensor
    By brian a in forum General Grand Prix Discussion
    Last Post: 05-24-2012, 05:57 AM
  5. bad crankshaft position sensor?
    By ChdMcD in forum General Tech Discussion
    Last Post: 08-13-2010, 01:06 PM
