Thread: Snout seal replacement.
Results 1 to 7 of 7
  1. #1 Snout seal replacement.
    Feb 2009
    Winnipeg
    Hi I was wondering if anyone could tell me how you would go about changing a leaky snout seal on the M90 supercharger?
  2. #2 Re: Snout seal replacement.
    Bastard Reptile's Avatar
    Kansas City, MO
    Remove Pulley, use screwdriver to remove seal, and then install seal.
    sounds simple, right? LOL
  3. #3 Re: Snout seal replacement.
    Jersey
    Quote Originally Posted by Reptile View Post
    where do you get this seal? Dealership doesn't carry them along with snout bolts.
    16' wrx sti- stock
  4. #4 Re: Snout seal replacement.
    SE Level Member Sinister Drag Designs's Avatar
  5. Likes ThatOldCarSmell liked this post
  6. #5 Re: Snout seal replacement.
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    No argument there, but I find is better to ask those who have done it than just jump in assuming it is as presented. Lol been burned by that once or twice
    Quote Originally Posted by Sinister Drag Designs View Post
    Link doesn't seem to work, but I'm interested. Any reasonably priced options on the pulley puller?
  7. #6 Re: Snout seal replacement.
    Apr 2020
    Upstate SC
    Quote Originally Posted by 99prixgt View Post
    ZZP has an option for the seal also
  8. #7 Re: Snout seal replacement.
    HUDSON
    I just did this on a spare M90 I have as a "back up". It may be tempting to use a three jaw puller on the pulley, but dont! A three jaw puller will damage the pulley. Use the type of puller
    specifically made for the job like the one ZZP offers. I bought one (pulley puller/installer) from ZZP ten years ago when I did the snout seal on my original supercharger currently installed on my car, it works to not only removes the
    pulley, but also installs it, it is worth the money. Once the pulley is removed, there should be a seal retaining spring clip in place that will just pop out with a screw driver, then the seal can be removed. I removed the seal by drilling
    a 1/8th" pilot hole in the seal and inserted a wood screw to use pliers to pull the seal out. The snout area around the seal must be cleaned, then the new seal can be installed by first lubing the shaft with supercharger oil, then lube the
    circumference of the seal with the oil, and also put oil on the seal surface that contacts the shaft. The seal will push into the snout by hand and stop at the correct depth automatically. Wipe away excess oil, reinstall seal retaining clip,
    then use the puller/installed to re-install the pulley. The pulley is properly positioned when the hub of the pulley is flush with the end of the snout shaft, just in case this note was not taken before dis-assembly. Oh yea, the there is a
    vent plug in the end of the snout shaft that must be removed first before attempting to remove the pulley.
  9. Likes ThatOldCarSmell liked this post
  1. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  2. rubber seal around winshield
    By Tyler_06 in forum Visual/Body Modifications
    Last Post: 07-23-2010, 07:04 PM
  3. Rack and Pinion Seal replacement
    By webracin in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2010, 12:24 AM
  4. front oil seal
    By sloppyjoe616 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:15 PM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
