Thread: 2004 GTP Check Engine Light flashes
Results 1 to 7 of 7
  1. #1 2004 GTP Check Engine Light flashes
    Nov 2012
    Tracy, CA
    When coming down a steep, long grade from about 4000 ft elevation ( Grapevine on I5, north of Los Angeles ) at highway speeds (65 to 70mph) my CEL will flash on and off several times, only staying on for about 5 to 10 seconds.
    Otherwise, CEL is never on.
    Engine seems to be running fine. No codes.
    It's a stock GTP.
    Anyone have this happen ?
    What was the cause ?
    Thanks...
  2. #2 Re: 2004 GTP Check Engine Light flashes
    St. Louis
    Usually a flashing CEL is an active misfire that may damage the cat converter. Next time it does it scan the car w/o shutting it off and see if you can pull a code.
  3. Likes Gingershrek liked this post
  4. #3 Re: 2004 GTP Check Engine Light flashes
    flashing cel means you need a tune up real bad, or the cats clogged up causing the misfires. next time it does it, scan for codes engine running, dont turn it off or the pending code will clear on you.
  5. #4 Re: 2004 GTP Check Engine Light flashes
    Nov 2012
    Tracy, CA
    OK. I drove the car some more at highway speeds and did get two pending codes after the CEL flashed once or twice .....
    P0137 [ O2 Sensor circuit low voltage B1S2 ]
    and P0303 [ Cylinder 3 misfire ].
    Then I shut the car off, let it cool down a bit, then drove it again at highway speeds and the CEL came on and stayed on. Pulled P0303 code at that point,
    with none pending.
    Engine appears to run fine. Plugs and wires were changed when I did the LIM and UIM gaskets back in March timeframe. Also put new o-rings on all
    the fuel injectors then.
    I did have a P0420 [ Cat Sys Eff below threshold - Bank 1 ] set the CEL several months ago. But I cleared it and it has not come back.
    I have never seen P0137 or P0303 before this.
  6. #5 Re: 2004 GTP Check Engine Light flashes
    GTP Level Member
    Oct 2014
    #3 coil going bad??
  7. #6 Re: 2004 GTP Check Engine Light flashes
    Nov 2012
    Tracy, CA
    Yeah. My first guess was the coil. They are original and the car has about 133,000 miles on it and I believe the coils are original.
    I see the AC Delco unit on RockAuto for about $40.
    Is there any way to test them ?
  8. #7 Re: 2004 GTP Check Engine Light flashes
    swap that coil with one of the others, see if the misfire moves. (plug wires need to go where they started, so you only move the coil, not the wires off them) if it dont move swap the spark plug wire with the plug next to it, if it still dont move pull the spark plug check its not smashed, or has a crack in the porcelain.
    if it still dont move after all that jazz the icm, or a injector could be the cause. injector swap with the one next to it would be the next free test. then you can get the icm tested at autozone part stores and others im sure.
  1. Check Engine Light on 2004 GTP Comp G
    By daltman360 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2013, 09:20 PM
  2. Replies: 9
    Last Post: 01-06-2012, 11:37 AM
  3. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  4. Pours blue smoke, wont idle, check engine light flashes!?
    By 1fastz71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-25-2010, 09:13 PM
  5. Right signal light flashes fast, left signal flashes normal speed?
    By nboylie in forum General Tech Discussion
    Last Post: 11-23-2009, 06:38 PM
