Thread: Header install question
Results 1 to 20 of 36
  1. #1 Header install question
    Mar 2019
    Nevada
    So I’ve been putting some SD headers on my GTP and finally about done. I took the advise of most and bought new stepped clamps to use instead of the U bolts provided. On the rear header where the cross over slips into it how do I clamp it there? Where it slips into it there is a metal piece supporting the cross over to the header and so I can’t slip the clamps over them. Hope that makes sense.
  2. #2 Re: Header install question
    Have a picture?
    From what I remember year ago I just put the clamp on the cross over pipe above the transmission and side the clamp all the way down to the bottom where it meets up with the rear header.
  3. #3 Re: Header install question
    Mar 2019
    Nevada
    In the circled part. Metal piece connecting collector to header. Or do I only slip it on and clamp at the very top? Seems like it wouldn’t have enough space to get a good clamp.
  4. #4 Re: Header install question
    I guess I don't remember what mine looked like and if that support piece was there. I put headers on my car way back in 2011-2012 I think. Don't have the car anymore.
    I'd cut the support off and move it down, re-weld it or just see how much of the clamp you can get on there and see if it leaks.
  5. #5 Re: Header install question
    Jul 2017
    macomb mi
    I can try to take a pic of my setup when I get off work I remember I used the clamps it came with only one that came off is the connection you see right by the flex joint in your pic that thing popped clean off after a few redlines haha ended up just having a shop weld it everything else I used came with the headers except gaskets at the heads don't remember cutting anything only remember the pain to fit that piece in and that I had to bang out the firewall to fit an o2 you should be able to just put that clamp on with that room let me confirm though
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  6. #6 Re: Header install question
    they fuked up on the build, that should be below the slip joint. you'll have to cut it off to get a band clamp on there.
  7. #7 Re: Header install question
    Apr 2015
    Columbus, OH
    Wtf. It should be way further down on that pipe. Here's mine.
    Wish you the best getting that crossover to not leak. I'm letting a half tube of muffler cement cure right now. I could have just screwed the install though, like 5 times.
    Top Swapped 01 Imp
  8. #8 Re: Header install question
    Mar 2019
    Nevada
    That sucks! I wish I would have realized this before installing them. Any chance a U bolt and muffler cement will work?
  9. #9 Re: Header install question
    the thing about U clamps is they crush the pipe, now they dont come apart so easy any more. there are thin band clamps, like a inch wide. slp has em SLP Performance Exhaust Band Clamps 308940020 - Free Shipping on Orders Over $99 at Summit Racing
  10. #10 Re: Header install question
    May 2008
    Schuyler, NE
    Cut that bracket off. Use the band clamps you have and smear lots of copper rtv all over the pipe connection.
  11. #11 Re: Header install question
    Mar 2019
    Nevada
    While I figure out what I’m gonna do about that next problem I’m running into is how do I re-connect the upstream 02 sensor? There isn’t enough room between the header and the tunnel like wall it’s in. Here’s a pic.
  12. #12 Re: Header install question
    May 2008
    Schuyler, NE
    You either have to take a hammer and dent the tunnel or get a shorter o2 sensor.
  13. #13 Re: Header install question
    the o2 part sucks. i ended up getting a custom dp made for my sd headers, so i had them install 2 bungs in the curved pipe for the o2 and the wideband. then i cut the o2 plug off the cars harness and made it 3 foot longer and re routed it down the strut tower to the rack then the dp.
    some shops have a plug you can put in the unused o2 bung to seal it off.
  14. #14 Re: Header install question
    Mar 2019
    Nevada
    I just took everything off. And when I’m not tired and frustrated, i’ll just dent the firewall out a bit. Thanks guys. This install is a pain. Doable, just a pain in the ass lol
    I’m in Vegas so it’s hot as hell in the garage so I can only work for so long before I’m sweaty and tired lol
  15. #15 Re: Header install question
    i feel ya, it was 100 here today, but add lots of humidity. you need to cut a hole in the wall and install a large ac unit. what id do
  16. #16 Re: Header install question
    Mar 2019
    Nevada
    Scotty where did you get the upstream 02 sensor bung welded in? Any chance you have a pic? Is it still above the flex pipe?
  17. #17 Re: Header install question
    like i said mines custom now. the v band is off the bottom of the header to solid pipe that curves under the car to the new flex then the cat. in th epic is the v band clamp so they are a few inches below the bottom of the header. in your case you can go past the goose neck or in it, but id rather have it up higher under the car.
    Header install question Attached Images
  18. #18 Re: Header install question
    any muffler shop should be able to drill the hole and weld in a bung. the bung is like 5 bucks here in hand. welded in, the last one cost me 30 bucks in my truck, they put it up on the lift drilled and welded it in.
    if you walk in part in hand id hope its like 20 bucks to do.
  19. #19 Re: Header install question
    Mar 2019
    Nevada
    So I can have a bung welded right here where I circled, and that would work ok? The headers came with a bolt in the 02 bung would that work to plug it?
  20. #20 Re: Header install question
    May 2008
    Schuyler, NE
    Yes that will work as long as you have no exhaust leaks and your o2 extension is long enough.
  1. Header install question almost done!
    By h0wl0ngcanitbe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2013, 10:02 AM
  2. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
  5. OBX Header Install is Done!!
    By Uno99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 12:43 PM
