Thread: Maximum Injector Pulse width 2004 GTP L32
Results 1 to 7 of 7
  1. #1 Maximum Injector Pulse width 2004 GTP L32
    SE Level Member chrisrexmandie's Avatar
    Sep 2018
    NC
    I was wondering if anyone knew what the max pulse width is for the stock L32 injectors are? When running a scan my Injector duty cycle topped out at 113% but the pulse width had only a max of 22ms. I recall reading somewhere that there's a scaling issue either in the VCM scanner or the PCM its self when it comes to the injector pulse width. My car doesn't fall on its face or go lean when the injector pulse width goes over 100%. My AFR stays at a steady 11.0:1 and the upstream O2 sensor sits at 900mv even after the injectors "max out". Just looking for some information because I feel like i shouldn't be needing new injectors since I have the stock pulley. I also performed a Injector balance test and they all dropped key on fuel pressure the same amount.
  2. #2 Re: Maximum Injector Pulse width 2004 GTP L32
    what mods you got? a 3.2 pulley will just about max out the stock injectors.
  3. #3 Re: Maximum Injector Pulse width 2004 GTP L32
    Sep 2018
    NC
    I have the stock 3.8 pulley, cold air intake, 3 inch catless downpipe, Tune, autolite 104, 180stat
  4. #4 Re: Maximum Injector Pulse width 2004 GTP L32
    your no wheres near maxing em out yet then.
  5. #5 Re: Maximum Injector Pulse width 2004 GTP L32
    Sep 2018
    NC
    Thanks! its just weird to see the duty cycle so high.
  6. #6 Re: Maximum Injector Pulse width 2004 GTP L32
    May 2008
    Schuyler, NE
    Yeah it's not right. You can see pw in the 30's on 04+ cars.
  7. #7 Re: Maximum Injector Pulse width 2004 GTP L32
    Jun 2021
    20ms is the max pulse with my scan tool shows when I shift to 2nd right before redline. If I waited any longer to tap shift 2nd gear I would hit the rev limiter
  1. What is maxium pulse width on 04+?
    By J57ltr in forum PCM Tuning
    Last Post: 03-29-2016, 08:41 PM
  2. torque app injector pulse width ??
    By mullman2002 in forum Introductions/Noob Questions
    Last Post: 09-20-2015, 06:45 PM
  3. Injector Pulse
    By tomtom123 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2014, 05:34 AM
  4. P0753, P0758, P1860, 1-2 and 2-3 shift solenoid and TCC pulse width modulator errors
    By STOCKTA in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2013, 08:36 AM
  5. Maximum width on Gp
    By Dunes2006 in forum Tires & Wheels
    Last Post: 06-19-2012, 11:58 PM
