Thread: Injector Pulse
Results 1 to 5 of 5
  1. #1 Injector Pulse
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Just wondering what Injector Pulse Width should be when at idle?
    Mine is between 2.6 and 3.2 at idle and I was told this is a bit high, like double what it should be. And my stock injectors go upward of 17 - 18ms of pulse width at WOT depending on the situation. They are usually around 16.6 - 18 for the most part at WOT. This is on stock injectors from my 99 GTP and a 3.4" pulley. I was told this is rather high as well.
    I sea foamed the vacuum lines and have no leaks, and I also sea foamed the gas tank. Half a can in vacuum lines, half a can in gas tank.
  2. #2 Re: Injector Pulse
    Sounds fine to me on both accounts.
    I just looked at log I did a long whiel back and in gear at idle was 2.7ish. WOT can reach 16-18 on stock injectors, once you are pushing 19-20 then your duty cycle is reaching it's limit of 80-85%.
    On that same log I was pushing 17-18 pulse width and only saw 75-78% duty cycle. But I also command around 11 AFR and it dropped to 10.8 once I hit past 5,000 rpms.
  3. #3 Re: Injector Pulse
    Aug 2011
    Michigan
    Alright. Good to know. I recently got my car tuned and so far it seems overall nicer to drive. As I get more things figure out, I want to work on dropping to my 3.2" pulley =)
    On the 3.2" pulley I saw about 19.5 once on pulse width and I thought above 17 was kinda pushing it so I pulleyed up to the 3.4"
  4. #4 Re: Injector Pulse
    Yeah.,.very normal. Keep in mind that it'll have to do with fuel pressure (more pressure is less pulse, but regulator should keep pressure constant)
  5. #5 Re: Injector Pulse
    Aug 2011
    Michigan
    When I tested pressure I was at 43 at idle with a new stock pump
  1. No spark or Injector Pulse.
    By rf2009 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2013, 10:51 PM
  2. no injector pulse?
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2013, 12:14 PM
  3. headlights flicker and pulse.
    By 97gpl36 in forum General Tech Discussion
    Last Post: 07-01-2013, 05:29 PM
  4. How-to add LED's & have them pulse from amplifier
    By mousemonster1232 in forum How To Write-Ups/Tech Tips
    Last Post: 03-17-2011, 06:46 PM
  5. need help asap no injector pulse 5th cyl
    By jenkins6586 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 06:47 PM
