Thread: KR on stock pully with Flow mods
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: KR on stock pully with Flow mods
    Jul 2017
    macomb mi
    could he be getting what intense claims as "false Knock" just making a suggestion not sure how it works but they have a kit that seems to be some type of shield that goes around the knock sensor and trans? maybe it could be a possibility lol check out the kit out there website and let me hear what you guys think I've always wanted to know more about it. left a link below.
    INTENSE Racing: Dynamat False Knock Elimination Kit
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  2. #22 Re: KR on stock pully with Flow mods
    Kemmerer, Wyoming
    I don't believe in false knock
  3. #23 Re: KR on stock pully with Flow mods
    Jul 2017
    macomb mi
    Quote Originally Posted by SgtMarshal View Post
    yea I didn't think it was a thing or else I would've probably bought it only being $12 and looking relatively easy/fun to install haha but just thought id recommend it maybe a rare case/scenario lol
  4. #24 Re: KR on stock pully with Flow mods
    Quote Originally Posted by 04lss View Post
    I am not, I'm mainly going with ZZP because of the store credit I have. Should be able to get the PCM for about 25 bucks.
    I checked the o2 sensor and it stayed at 1 volt (probably torque rounding) at WOT.
    you need to scan for MV iirc for the o2 to read real numbers, not 100% sure t app can do that.
    the volts one you got, as you idle or drive around it should bounce up and down pretty fast.
  5. #25 Re: KR on stock pully with Flow mods
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    1 volt is really rich, that might cause some kr
    It is running -5% LTFT I an never remember if that means its inclined to run rich or lean.
    I went to install the new pulley tonight. Its raining and about 40* But i was like screw it. Turns out i dont have a 15/16" socket or wrench. I guess ill finish up on friday.
    2017 GTI 6mt 320whp 400wtq , 2012 Volvo S60 T6 300hp of Swedish safety, (Sold) 2019 Ford Mustang GT. 460 screaming eagles. 2004 Buick Regal GS "Gramps" Intercooled, corn fed, ported g3 m90, 1.9 rockers, 80# injectors.
  6. #26 Re: KR on stock pully with Flow mods
    yeah thats a 1/2 drive socket and ratchet on the drive bolt. a ratchet is far faster then a open/box wrench. ive used a breaker bar to get it going too. that first crack is kinda scary sounding but after that it comes off pretty easy.
  7. #27 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    Ill toss the socket I buy in when i return it. my contribution.
  8. #28 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    So I got the new pulley on and as expected 6* of KR on a 3.5. Its also running an LTFT of -10% at idle. That means that the car is running really rich right?
    I also have noticed that i hear a hissing sound when i turn off the engine coming from somewhere near the manifold for a few seconds. Almost sounds like pressure escaping.
    What could be causing the car to run so rich, that i can realistically troubleshoot?
  9. #29 Re: KR on stock pully with Flow mods
    Kemmerer, Wyoming
    could be your O2 sensor, more than likely it's your tune. zzp also has a knack for richening up the tune. might be a good idea to pick up an HP Tuner and cut some fuel yourself.
  10. #30 Re: KR on stock pully with Flow mods
    he has no tune. might be the pcm learning the new pulley to some degree. either way its time for that tune.
    i should just do a free rental on my dhp for ya lol i could remote tune ya. hardest part is getting it set up on a laptop, its a battle for some ppl.
  11. #31 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    DHP is still a thing? im more than willing to buy an AVT interface. Is there somewhere to get the software so i can fiddle? worse case i can set up windows xp on a vm.
  12. #32 Re: KR on stock pully with Flow mods
    Kemmerer, Wyoming
    avt is done for, I would take scott up on his offer and rent the dhp. really only a couple maf adjustments will take care of that richness, maybe several adjustments.
    edit: you can get dhp to work on a windows 10 machine, just requires one or two extra steps. I have it on mine.
  13. #33 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    Welp,
    I shouldn't have sold the one I had. Scotty id definitely be interested in doing that when i get paid.
  14. #34 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    For some reason i recall reading that the shorter dogbones and polly mounts can cause false knock. Am I crazy, or is that a thing?
  15. #35 Re: KR on stock pully with Flow mods
    Kemmerer, Wyoming
    I don't believe in false knock and I don't see how that could be true
  16. #36 Re: KR on stock pully with Flow mods
    Jul 2017
    macomb mi
    I have short dogbones and lower poly mounts whenever people are in my car they ask if my brakes are bad since whenever im coming to a stop the engine vibrates the whole car and it feels like extremely warped brakes haha I always explain to them that im kinda an idiot and mod my car to the point where its uncomfortable for the average person lol and I don't get any knock on my setup and I believe im on either 16 or 18 degrees of timing at WOT ill have to see if the summer heat changes that but it was 70 out yesterday and still nothing
  17. #37 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by tzerilli View Post
    I think im going to remove the shorter dog bones. Ill keep the polly mounts. I also think im going to reinstall the stock airbox, im not a fan of the sucking noise at idle from the open cone. I have a K&N drop in, and i can open up the front of it if needed.
  18. #38 Re: KR on stock pully with Flow mods
    May 2008
    Schuyler, NE
    False knock rarely happens. Fill up with race fuel if you want to see if it's real or false.
    You need a wideband to see if you're running rich or not. The narrowband tells you absolutely nothing at wot.
    You basically have no mods that make a difference as far as kr is concerned. I'm surprised you dont have more than you do.
  19. #39 Re: KR on stock pully with Flow mods
    Sep 2014
    Richmond Virginia
    The downpipe doesnt help KR? Isnt the ubend in the stock DP one of the biggest causes of KR on a stock car?
  20. #40 Re: KR on stock pully with Flow mods
    May 2008
    Schuyler, NE
    Very little. Most think there is a gain because they are replacing a half-clogged cat.
    The cause of kr is heat from the blower. Cooling the air charge is the only thing that makes any sort of significant difference.
  1. For sale: Stock DP with Magnaflow hi-flow cat less than 5k miles.
    By Runicdionysus in forum For Sale - Parts
    Last Post: 09-18-2014, 04:41 PM
  2. stock (allegedly) gtp with flow mods nets 10 degrees kr at wot?
    By Leiliel666 in forum General Grand Prix Discussion
    Last Post: 08-19-2014, 03:55 AM
  3. Should I use a stock belt with a 3.5 pully?
    By ncccgolf5 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 08:24 PM
