Quote Originally Posted by 04lss View Post
I am not, I'm mainly going with ZZP because of the store credit I have. Should be able to get the PCM for about 25 bucks.
I checked the o2 sensor and it stayed at 1 volt (probably torque rounding) at WOT.
you need to scan for MV iirc for the o2 to read real numbers, not 100% sure t app can do that.
the volts one you got, as you idle or drive around it should bounce up and down pretty fast.
