Thanks for that video link. They are doing the lifters and valve covers too. I only need to do the Lim and uim and the rear valve cover,, I did the front one a couple of years ago and it is not leaking... I also replaced both coolant elbows with the aluminum ones a couple of years ago. And still no leaks on either. So for what I am doing do I have to remove the alternator and bracket or will I have a hard time getting the coolant elbow that goes on to the side of the Lim back on ? I have a new aluminum elbow for there. Can the back valve cover and Lim be removed with the alternator and bracket on the engine ? Should I remove any of the pulleys or the coil pack to do what I need to do ? And finally .... Is there a special tool to remove the fuel line from the fuel rail or should I just relieve the pressure and leave the fuel rail attached to the line and just flip it out of the way ? Thanks guys !!!!! Just trying to disturb as few parts as possible and since you have already been thru this... I few final tips would be a big help! 😀
