Thread: 2004 GTP has coolant on top of intake manifold
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41 Re: 2004 GTP has coolant on top of intake manifold
    right click the pic on ra, then copy image addy paste it here as a link or try the URL tab in th epic icon.
  2. #42 Re: 2004 GTP has coolant on top of intake manifold
    that tb gasket should fit in a groove in the tb.
  3. #43 Re: 2004 GTP has coolant on top of intake manifold
    Nov 2012
    Tracy, CA
    Thanks for all the help so far guys!
    I have to put the re-assembly on hold until I get my new UIM gasket form RockAuto.... it's on the way..
    And I get back from a trip I am going on .....
    Hopefully the second one they send is the right one .....
    You can see why there is some confusion about which one is the right one, Felpro has two different gasket designs
    with the same PN ,,,, This Amazon link shows the two ..
    Amazon.com: felpro ms96789: Automotive
    I will let you know how it all goes when I get finished.....
  4. #44 Re: 2004 GTP has coolant on top of intake manifold
    why are you buying another kit, or a kit at all? the sc gasket is like 11 bucks at your local parts store, the t stat gasket is like 2 or 3 bucks, cant see the tb gasket costing more then 5 bucks.
    hell you can rtv the tb on there really.
  5. #45 Re: 2004 GTP has coolant on top of intake manifold
    Nov 2012
    Tracy, CA
    They all had it as a kit..... Autozone, O'Reilly, NAPA. RockAuto had the best price for the kit.... $28. The uim gasket for the 2004 - on must be more expensive than the one used
    on 2003 and older..... I'm getting a free replacement from RockAuto....
  6. #46 Re: 2004 GTP has coolant on top of intake manifold
    ah didnt know it was the metal gasket, thats 100% reusable if you didnt know that. unless it got mangled.
  7. #47 Re: 2004 GTP has coolant on top of intake manifold
    Nov 2012
    Tracy, CA
    OK. I am back from vacation and finishing up the LIM gasket replacement on my 2004 GTP.
    The LIM and S/C are back on. I did find the same type of S/C gasket that was on the engine previously, the one with the two o-rings attached
    to it, at ZZP.
    I am now up to putting new o-rings on the fuel injectors. The old ones are black on the manifold end and blue on the rail end.
    They both looks to be about the same size as far as the inside and outside diameters and the cross-section thickness.
    However, the ones that came with the FelPro LIM gasket set are of two different sizes, one has a thinner cross section than the other.
    They are obviously not the right ones for this application.... possibly the thicker cross-section one is, but not the thinner one.
    So, where have you found the right o-rings ? And who is the manufacturer and PN ?
    My engine is stock .... The car is a 2004 GTP Comp G model.
    Thanks in advance for your help!!!
  8. #48 Re: 2004 GTP has coolant on top of intake manifold
    GTP Level Member CHI2000GTP's Avatar
    Dec 2015
    Chicago, IL
    The injector o-rings need to be bought separately. The kits come with similar looking, round o-rings but I remember none of those fit, like you said. I bought the ones for my injectors at Advanced. They were also Felpro. Don't have PN for ya, but they should show up in their computer systems once you tell them it's a 3800 engine.
    Buy extra ones, they like to tear when you're pushing in the injectors.
  1. GP Upper and Lower Intake Manifold Coolant Leaks
    By GPCharlie in forum General Grand Prix Discussion
    Last Post: 04-01-2015, 11:36 AM
  2. Coolant sitting on top of lower intake manifold?
    By Jackal in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-09-2014, 10:33 AM
  3. 2004 GP-GT2... blown intake manifold, overheating, etc
    By gunbunny in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-17-2012, 09:07 AM
  4. Intake manifold leaking coolant?
    By hansz92 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2012, 06:08 AM
  5. 136,000 miles, losing coolant, intake manifold gaskets shot from DEX COOL ???????
    By Skillet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-17-2011, 10:51 PM
