Thread: interesting misfire issue
Results 1 to 14 of 14
  1. #1 interesting misfire issue
    Dec 2018
    Lehigh Valley, PA
    I know there are tons of misfire threads, but never have I seen the issue I'm having now, and it's so weird that it's actually somewhat entertaining. What started off as a misfire under load (no CEL) has gotten gradually worse to where I finally did get a CEL (random multiple misfire), but part throttle driving is totally unaffected. So far I've inspected the plug wires for damage, and took the metal shields off the spark plug boots. I haven't bothered checking the coils or ICM yet, because I should be getting a set in the mail tomorrow, so I'm just gonna swap it all over. I still need to check the plugs as well. PO said they're new, and they're AC Delcos, but I don't know which "flavor" he used, or if he bothered gapping them. Here's where it gets weird.... driving to work today, all of a sudden I was getting alternator noise through my speakers, and the stereo wasn't even turned on. It would get pretty loud as I stepped on the throttle, then it would cut out and the car would drive as normal until it happened again. The misfire didn't really get any worse during the "noise storms" but if it did, I probably just could hear it over that noise. Maybe a rectifier in the alternator blew out? I wish it wasn't so cold out so I could check all these things properly without losing fingers to frostbite.
  2. #2 Re: interesting misfire issue
    Dec 2018
    Lehigh Valley, PA
    It was the coils. 2 originals reading just out of spec and one aftermarket reading perfect. Put used original ones on from a low mile 2005 Monte SS sc and the car runs great now. If I get the radio noise again, I’ll see if it’s possible to change just the condenser on the alternator. I’d hate to change the whole alternator because of a 50 cent part.
  3. #3 Re: interesting misfire issue
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Strange! Glad you got it fixed though. It's amazing how these things can fail gradually and never show a cel.
  4. #4 Re: interesting misfire issue
    I have seen a similar issue where no codes were tossed etc. It's interesting, but once in a while shotgunning a part on is the only way to find the solution.
  5. #5 Re: interesting misfire issue
    Dec 2018
    Lehigh Valley, PA
    Yeah, and when you get an opportunity to buy an original low miles set of coils and ICM for 40 bucks, you take it, lol. So now I still have a spare ICM too....bonus!
  6. #6 Re: interesting misfire issue
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    Wow. Misfires caught my attention. (I used to get sound through my speakers when passing a particular TV station transmitter).
    Is it likely for ICMs to go bad? I've had an intermittent misfire for a long time and am still trying to solve it w/o remove-and-replace policy ($). ('05 GTP; have replaced plugs, wires, injectors, checked vacuum lines; have not replaced crank position sensor or ignition coils).
    Pardon the deviation from your thread, but I have been wanting to replace the ICM but don't want to just throw "possible" parts at the problem anymore.
  7. #7 Re: interesting misfire issue
    Dec 2018
    Lehigh Valley, PA
    search ebay and keep an eye out for a good deal. Sometimes you can find stuff so cheap it doesn't make sense to not buy it. My whole ICM with all 3 coils was $40 shipped to my door.
  8. #8 Re: interesting misfire issue
    Oct 2011
    Ohio
    I see. Some even sound trustworthy (I once tried this with one from a junkyard module - either it was incompatible or bad; I assumed the normally asiprated GP was not compatible since the car ran horrible). Do you know if it's the same ICM through all GP models? I'm seeing several part numbers (of which there MAY be backward compatibility but not the correct replacement for supercharged (GTP).
  9. #9 Re: interesting misfire issue
    icm's are the same.
  10. #10 Re: interesting misfire issue
    Pennsylvania
    Can we get this guy a ban or something? He’s posting ads all over the place.
  11. #11 Re: interesting misfire issue
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    I 2nd said request for BAN
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  12. #12 Re: interesting misfire issue
    Dec 2018
    Lehigh Valley, PA
    Lol, I guess he got banned, I don't see the posts you guys are referencing!
  13. #13 Re: interesting misfire issue
    May 2016
    Rouge Island
    Quote Originally Posted by CopperGTP View Post
    German spammer, our Admin removed his posts and banned him. He posted the same lame stuff to 8 different threads in 10 minutes trying to make look like he was a car guy.
  14. #14 Re: interesting misfire issue
    MasterOfPuppets91 this tard, is gone....i warned him too.
  1. Misfire Issue
    By ItaliaGTP35 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2015, 07:39 PM
  2. interesting issue at hand
    By fordmudr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2012, 12:35 AM
  3. Misfire issue/question
    By mousemonster1232 in forum General Tech Discussion
    Last Post: 01-13-2011, 11:24 PM
  4. misfire issue
    By SS98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2010, 09:12 PM
  5. Interesting issue I cannot seem to figure out....
    By Iron Indian in forum General Tech Discussion
    Last Post: 06-20-2009, 06:55 PM
