Thread: Carbon cleaning supercharged engine
Results 1 to 12 of 12
  1. #1 Carbon cleaning supercharged engine
    SE Level Member LouF's Avatar
    Oct 2011
    Ohio
    I've been wanting to do a carbon cleaning with water (possibly steam) but was deterred by the supercharger ('05 GTP). I've used Seafoam, but I've had good results just using water (on other vehicles). I recall, the GTP did not like to have the brake booster vacuum line disconnected or throttle body disconnected from the intake box.
    I probably should freshen up vacuum lines too.
    Comments?
  2. #2 Re: Carbon cleaning supercharged engine
    Oct 2011
    Ohio
    Well, I did it, and it really runs smoother. Since making my vacuum restricter, it will be much easier to do regularly.
    The vacuum restricter is a cap that I put a small tube through so it can very uncontrollably sip water out of a container. It works well, and I did a 2-cup cleaning.
  3. #3 Re: Carbon cleaning supercharged engine
    Oct 2011
    Ohio
    ...very controllably...
    What, posts can't be edited and photos can't be cleaned out in the attachment manager??
  4. #4 Re: Carbon cleaning supercharged engine
    i spray water and meth right through my supercharger, wonder if it keeps it clean?
  5. #5 Re: Carbon cleaning supercharged engine
    it leaves the inside of the case/rotors and LIM green btw.
  6. #6 Re: Carbon cleaning supercharged engine
    green tint is better then black carbon i suppose.....
  7. #7 Re: Carbon cleaning supercharged engine
    Kemmerer, Wyoming
    water/methanol didn't turn my supercharger green, just ate the coating.
  8. #8 Re: Carbon cleaning supercharged engine
    Oct 2011
    Ohio
    Apparently it does (the combustion chamber).
    AEM Performance video
    How Water/Methanol Injection Works & How It Makes Horsepower in Gas Engines - YouTube
    3:09
    Also, good conversation here:
    Decarbonizing an Engine with Water: Myth or Fact? | Physics Forums
    I might have to use Seafoam to get the intake valves.
  9. #9 Re: Carbon cleaning supercharged engine
    Quote Originally Posted by SgtMarshal View Post
    did you use the windshield washer fluid that had the blue dye in them?
  10. #10 Re: Carbon cleaning supercharged engine
    Kemmerer, Wyoming
    I just used distilled water and methanol. works good.
  11. #11 Re: Carbon cleaning supercharged engine
    that's why mine was green lol.
  12. #12 Re: Carbon cleaning supercharged engine
    cool, i must have ran 12 gallons of washer fluid through mine before getting my hands on real meth.
  1. Cleaning a carbon fibre vinyl
    By egyptiansuperman in forum Introductions/Noob Questions
    Last Post: 10-03-2014, 01:50 PM
  2. Carbon cleaning
    By Jtiger360 in forum Introductions/Noob Questions
    Last Post: 01-05-2013, 12:23 PM
  3. Engine bay cleaning
    By Russosaur in forum Visual/Body Modifications
    Last Post: 09-16-2012, 09:39 PM
  4. engine cleaning
    By busagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-17-2010, 08:53 PM
  5. Engine Tuneup - Burning off carbon
    By 04CompG in forum General Tech Discussion
    Last Post: 10-30-2008, 08:38 PM
