I see. Some even sound trustworthy (I once tried this with one from a junkyard module - either it was incompatible or bad; I assumed the normally asiprated GP was not compatible since the car ran horrible). Do you know if it's the same ICM through all GP models? I'm seeing several part numbers (of which there MAY be backward compatibility but not the correct replacement for supercharged (GTP).
