Thread: Intercooler install
Results 1 to 13 of 13
  1. #1 Intercooler install
    Dec 2016
    Baltimore
    Hey folks,
    Just finished buttoning up my S2IC setup, yet when i put the SC belt on I noticed
    that it is rubbing against the bottom of the ICM bracket. Is there a mod or fix
    so I can hear this thing run for the first time in a year.
    TIA
  2. #2 Re: Intercooler install
    you can either put some spacers under the icm to lift it up, or you can take a grinder to the cast bracket and lop off a 1/2, then re drill the holes for the icm and blot it on.
    how i did mine, http://i1097.photobucket.com/albums/...t.jpg~original the cut and grind act.
    theres a thread how to do it by billboost37.
  3. #3 Re: Intercooler install
    Dec 2016
    Baltimore
    Was hoping you'd chime in. Been using your pics for reference. What type of spacers should i
    go grab? So, i take the bracket off and place the spacers on, re-tighten, than i'm good to?
  4. #4 Re: Intercooler install
    ive seen pics of people using longer bolts and nuts as spacers. i find it kinda ugly tho, why i opted to cut that 1/2 inch off the inside of the bracket and moved the icm over.
    the spacers will be the quick and easy route, being your beyond ready to run it.
  5. #5 Re: Intercooler install
    Dec 2016
    Baltimore
    Yea i think i'll go with the spacers, I still gotta run the tubes and install the front mount, so Im not
    exactly rushing. Just want to make it run before I take it get the trans rebuild.
    What you think Granger for those or a standard parts store?
  6. #6 Re: Intercooler install
    any place that sells bolts and nuts will do. bring one with you to match up the width of the bolts. then enough washers or nuts to lift it up enough to clear the belt. might want to do a test fit and see how much room you need. might be a inch or so.
    might even find some thick walled spacer tubing type stuff you can cut to size, would look better for sure.
  7. #7 Re: Intercooler install
    Dec 2016
    Baltimore
    Sweet. Im on it, i'll jump on that in the a.m. I'm trying to mirror your setup soon as i find
    replacement pushrods for my 1.8 rr to go with the 3.3 mps. Any tips for a brotha
  8. #8 Re: Intercooler install
    that i dont know much about, my rockers came with rods and all.
  9. #9 Re: Intercooler install
    Dec 2016
    Baltimore
    Mine did as well, just on my last Park Avenue build one rod bent i haven't re-used them
    since. Thought i'd throw them on while i had the down time
  10. #10 Re: Intercooler install
    I have to say.. doing this on a mock up... I wanted to see more guys do it
    How to clearance your stock cast bracket for an intercooler and belt BillBoost way
  11. #11 Re: Intercooler install
    hard to believe mine came out cleaner cut then yours did lol 1/8 cut off wheel straight down, then cut off at the bottom.
  12. #12 Re: Intercooler install
    I had an H body.. there was never a clearance issue.
    Mocked up a w body to prove a point for a friend. Seems far too easy to do and have all the clearance in the world.
  13. #13 Re: Intercooler install
    why i followed yer lead pal. cost me a cut off disk lol
  1. How to install your WBS Intercooler
    By machinegunsquid in forum How To Write-Ups/Tech Tips
    Last Post: 07-11-2019, 08:02 PM
  2. intercooler install
    By jrock in forum General Tech Discussion
    Last Post: 06-07-2012, 05:49 AM
  3. intercooler install
    By JROCK1987 in forum General Tech Discussion
    Last Post: 02-23-2012, 06:21 AM
  4. How to install stage three intercooler?????
    By GINOSGTP in forum General Tech Discussion
    Last Post: 02-25-2009, 07:52 PM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
