any place that sells bolts and nuts will do. bring one with you to match up the width of the bolts. then enough washers or nuts to lift it up enough to clear the belt. might want to do a test fit and see how much room you need. might be a inch or so.
might even find some thick walled spacer tubing type stuff you can cut to size, would look better for sure.
