Thread: P01260 - last test failed.
Results 1 to 20 of 26
  1. #1 P01260 - last test failed.
    SE Level Member JerzNick's Avatar
    Oct 2012
    New Jersey
    Anyone ever get this code? It started showing up after I dropped to a 3.0 and I noticed my ltft'a are always negative.
    Bored block, Eagle Crank, XP Cam, Ported Heads/LIM/Blower/TB, 3.0 Pulley, CAI, Headers, 42.5#, AL 104's, etc...
  2. #2 Re: P01260 - last test failed.
    Looks slightly familiar.. is that the "Please tell us what code it is" code?
  3. #3 Re: P01260 - last test failed.
    Since I'm a sarcastic jerk, I also looked it up.
    P1260 OBD Trouble Code
    1 result found
    Type Powertrain - Manufacturer Controlled DTC - Manufacturer Controlled
    Description Fuel Pump Speed Relay Control Circuit Conditions
    Cause Key on or engine running, then the PCM detected an improper voltage level on the Fuel Pump Speed Control PWM circuit, condition met for at least 30 seconds
    With that info, do you know any reason why the pcm is detecting soemthing with the fuel pump. Maybe you put a hotwire kit in place?
  4. #4 Re: P01260 - last test failed.
    GTX Level Member loopy smurf's Avatar
    Oct 2012
    Union, OH
    ... Maybe you put a hotwire kit in place?
    That's why I always go with the Travelocity kit instead...
    Sorry...couldn't help it...I'm leaving now...
  5. #5 Re: P01260 - last test failed.
    SE Level Member L67PWR's Avatar
    May 2013
    New Jersey
    lol Bill, the sarcasm is always welcome!
    Nope, no kit... this code just started happening when dropped to a 3.0 pulley.
    Maybe it's just coincidental?
  6. #6 Re: P01260 - last test failed.
    I've never heard of a fuel pump electrical issue code being linked to a round pulley. No.. I don't believe they are linked. Although if you changed the pulley, you dicked around with the fuse box. That code is likely from an issue with the box.
  7. #7 Re: P01260 - last test failed.
    Oct 2012
    New Jersey
    Checked every last fuse, wire, connector etc...
    Started to re-tune my LTFT's this morning. So far the code is gone and hasn't come back(so far).
    I wonder if the issue is from having constant negative ltft's....
    Tricky stuff
  8. #8 Re: P01260 - last test failed.
    Oct 2012
    New Jersey
    Bill, I have been testing and scanning left and right to no avail. The code only shows up on WOT runs... Perhaps my Fuel pump can't keep up? Or maybe I should do the Hotwire/Travelocity lol... any other ideas?
  9. #9 Re: P01260 - last test failed.
    I'm thinking you need to research that code further. Find some GM info on it to understand why what you are suggesting is not even in left field..it's in another whole ball field, in a different state from your code.
    See what it says will cause the code and then you can test/diagnose properly.
  10. #10 Re: P01260 - last test failed.
    Further research, I found a QC GP post about it, saying it's not technically a code for an 02.. but I'd want to check my GM FSM's first.
  11. #11 Re: P01260 - last test failed.
    Oct 2012
    New Jersey
    Guess I'll keep at it. Thanks for the info
  12. #12 Re: P01260 - last test failed.
    I might have a spare minute tonight. Post your vin please.
  13. #13 Re: P01260 - last test failed.
    Oct 2012
    Union, OH
    Quote Originally Posted by JerzNick View Post
    Maybe even Orbitz...
  14. #14 Re: P01260 - last test failed.
    Oct 2012
    New Jersey
    Vin: 1G2WR1219YF326906
    Thanks for any help.
  15. #15 Re: P01260 - last test failed.
    Oct 2012
    New Jersey
    Solved: Gt body is always high speed. Just had to turn off the error code.
  16. #16 Re: P01260 - last test failed.
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    So the gt fuel pump is always in run high mode
  17. #17 Re: P01260 - last test failed.
    Banned
    May 2008
    VA (was NY, MI, MN, FL)
    Quote Originally Posted by 97gtp01gt99gt View Post
    Almost all cars were high-only. The FP speed control relay/resistor was a commonly deleted or bypassed system on 3800 SC cars to eliminate the possibility of failure.
    Total guess, but with a SC tune and LTFT's wanting to reduce fuel, it could've been trying to enter low-speed mode and erroring due to the hardware not being there. Never looked into how detailed they programmed that system, so apply much salt to my guessing on that. Probably something in that realm of the pcm thinking it should be seeing that FP resistor and speed relay, though. Kill the DTC in the tune, and party on, if you don't have a car that came with that stuff.
  18. #18 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    So would this code cause my car to idle at around 1500 rpms
  19. #19 Re: P01260 - last test failed.
    Error Code P1260: Theft Detected Vehicle Immobilized makes it not run, so it cant be stolen.
  20. #20 Re: P01260 - last test failed.
    Sep 2018
    Saint Louis
    Tim from zzp said he never heard of this code one site says its theft detected and a gm DTC codes list says its fuel pump speed wiring either way I'm doing the zzp website procedure and installing pcm security relearn and case learn
  1. Failed Emissions Test
    By Biohazed in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2013, 09:24 AM
  2. zzp pcm failed so im swaping to a gtp pcm
    By Wisconsingrandprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2012, 01:46 PM
  3. Failed emission test again.
    By jokyfo in forum General Tech Discussion
    Last Post: 12-12-2010, 11:00 AM
  4. failed lim gaskets and you
    By 99prixgt in forum General Tech Discussion
    Last Post: 11-29-2010, 01:11 AM
  5. Just put up my Xmas lights and FAILED
    By glanzergtx in forum Off Topic Discussion
    Last Post: 12-05-2009, 12:30 AM
